Go Back   HVAC-Talk: Heating, Air & Refrigeration Discussion > The ARPA Zone/General Discussion Forums > Controls
Controls Discussions about HVAC controls in general including automation, DDC and pneumatics.
Reply
Thread Tools Display Modes
  #14
Old 11-10-2009, 04:56 PM
freddy-b freddy-b is offline
Member
Quote:
Originally Posted by rbricker View Post
You already replied to the email I sent you, and said you were forwarding it to your Business Manager, Susan.
I did. Yes.
  #15
Old 11-10-2009, 04:57 PM
tk2k tk2k is offline
Quote:
Does anyone know if any wizards exist that would allow programming from the Tridium interface?
I suspect the answer is no, and the only option is to use Rover.
There are no Trane wizards that I know of. With the AX software, you should be able to access the config parameters of the devices.
__________________
"I wish it were winter so we could freeze it into ice blocks and skate on it and melt it in the spring time and drink it!"
  #16
Old 11-10-2009, 09:40 PM
lontshooter lontshooter is offline
rbricker,
The first item is that the Trane controllers are Lon based, but need to be setup with Trane Rover or Tracer to make them function, they can be done thru a Lon Management Software i.e. Lonmaker as long as you have the plugin for the controllers, or you need to make changes in the browser function. The plugin is property of Trane and they don't release them to the general public that often, you can get the XIF file for the device.
Second item is that if your are looking for an Enterprise solution to integrate 100 buildigns togehter this Jene is not going to handle that many controllers, the one that they say they are using is undersized for the number of controllers that will be installed.
Thrid item is that this device is factory commissioned and you may not be able to change setting in the device.
Check this link.
http://www.lonmark.org/products/prod...?ProductID=244
Lontshooter
  #17
Old 11-10-2009, 09:46 PM
amigo's Avatar
amigo amigo is offline
Regular Member
Quote:
Originally Posted by lontshooter View Post
rbricker,
Check this link.
Lontshooter
looks like you can download some of their plugins from here:
http://trane.com/Commercial/DesignAn...ter.aspx?i=909
Although,I have not tried it.
  #18
Old 11-11-2009, 05:47 AM
willf650 willf650 is offline
rbricker,
Check this link.
Lontshooter
You have a little misinformation here.
The Trane LNS plugins are freely available to the public and always have been since their development. There would be a gap for the 580 controllers. There is no AX wizzard available. From the description of this project the overwhelming majority of these controllers will be ready to rock and roll without being touched with any software. Heatpumps are set up from the factory as are anything that comes in a piece of equipment minus the 580s. If they don't like the fact of the 580 they should ask for a different programable for the facility.
This could be an enterprise level solution but it does not consist of the controllers. It would consist of the workstation/supervisor software and this facility should seamlessly integrate to any web supervisor on the enterprise level. Although I would think the enterprise level integration of sites would be a seprate project.
You should be able to change any settings in these devices as freely as any other product. More so than some.
  #19
Old 11-11-2009, 07:13 AM
rbricker rbricker is offline
Regular Member
This could be an enterprise level solution but it does not consist of the controllers. It would consist of the workstation/supervisor software and this facility should seamlessly integrate to any web supervisor on the enterprise level. Although I would think the enterprise level integration of sites would be a separate project.
I expect the enterprise integration to be a separate project. I am just trying to get a system that is as compatible as possible with our planned enterprise system. The job originally specified ONLY proprietary ALC controls integrated to an existing WebCTRL server. I didn't think that was what we wanted for an enterprise solution and made a last minute change to allow a tridium system as an alternative option. So far I think we made the right choice.
I am, in fact, considering an option of trying to get a separate contractor to handle the tridium integration to the Trane system on this job, if the present contractor isn't able to provide adequate Tridium products and integration.
  #20
Old 11-11-2009, 07:34 AM
sysint sysint is offline
Member
Regarding Tridium wizards, from my understanding only Honeywell wizards can be launched in the Tridium box. Otherwise wizards are launched from a PC containing the work bench software. So, if Trane config software is available on the PC that has a copy of workbench the devices can be configured and then imported into the Tridium system.
The other option is maintain a LNS DB but for Tridium that can be a little more messy. However, Trane has LNS Plugins available. And, I do have to say when they first they had LNS plugins, they were not freely available. Since then they have added them to the website.
I think if you have made a decision for LON and Tridium it is more important and stick to all LON products if possible.
Reply
Tags
lns, lon, trane, tridium
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
» Sponsors
» Sponsors
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
HVAC-Talk is proudly provided by:
Contracting Business MagazineAd Management by RedTyger
© 2010 Penton Media, Inc.
