| Refrigeration & Ice Making Topics about Walk-ins, Display cases, Ice Machines and other refrigeration equipment |
06-30-2009, 11:05 PM
Regular Member
I'd stick with the LP control and 409 or equivalent gas.
I agree LP over T-stat in that app. is the best way to go.
Let the thing live and you'll also make that customer really happy by saving them some cash.
__________________
Always go hard and fast enough so that when you hit the ditch you can pull out the other side.
- Johnny Paycheck
07-01-2009, 09:07 AM
Quote:
Originally Posted by K_Neil
R414B is a drop in for 12 and it's OK with MO
or drop some MP39 in there
__________________
no one man knows everything, proper answers eventually create new questions
06-30-2009, 08:18 PM
Go with 409. You don't have the horsepower to do 22 if it was designed with 12 originally. Pressure control is the simplest way to do it, but if you're not comfortable with it, buy a thermostat. To set the control as is, get out your PT chart, and look at your setpoint box temp vs. saturation presssure for whatever refgt you choose.
06-30-2009, 08:28 PM
R409 Cut in 38 PSI, Cut out about 20 PSI. If you crank the SSV almost closed with your gauge on it, the unit will short cycle on the LPS and you can check your actual cut in and cut out from there, just be sure to set the cut in pressure first.
R134A, with a POE oil change in the old compressor. Cut in 33 cut out about 17.
Put on a site glass and charge until the site clears.
If the system is cycling very fast may be short on refrigerant, short on cycle followed by long off cycle may mean restriction or a failing txv?
07-04-2009, 02:35 PM
beckmech,
Here's what you have.
The JL-501 Copeland semi was replaced with a KAE-0050. It's not 70 yrs old, probably closer to 50.
1/2 HP
R-12 medium temp
4705 btuh @ +25 SST
95 ambient / 110 CT
It's an oldie, keep it going if you can and take pictures. Old running stuff is pretty cool to see.
07-01-2009, 09:48 AM
Location: somewhere between Raising He*l and Amazing Grace
I've used MP-39 with very good success also.
__________________
If guns are outlawed, only the government will have guns. Only the police, the secret police, the military, the hired servants of our rulers. Only the government -- and a few outlaws. I intend to be among the outlaws.
-- Edward Abbey
When a man in office lays out a dollar in extravagance, he acts immorally by the people. - Grover Cleveland
The problem with socialism is that you eventually run out of other people's money. -- Margaret Thatcher
| Thread Tools |
| Display Modes |
Hybrid Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
