Go Back   HVAC-Talk: Heating, Air & Refrigeration Discussion > The ARPA Zone/General Discussion Forums > Residential HVAC
Residential HVAC Questions and discussions pertaining to HVAC for the home. No pricing, no DIY, please read Site Rules Register
Reply
Thread Tools Display Modes
  #1
Old 04-24-2009, 01:21 PM
cooldude_9999 cooldude_9999 is offline
Regular Member
Confused Package Unit Life Spans
I'm trying to compare Gas/Electric Package Unit savings for single stage vs 2 stage/variable speed and different SEERs, but this is difficult without knowing how long the package unit will last.
I'm in humid Chesapeake, Virginia and not exposed to any extreme conditions (salty air, exposed to direct sun all day, etc.). What is a good average estimate of life span? 12 years..15?
Also, when comparing a simple Goodman single stage package unit to 2 stage A/C & heat and variable speed Yorks/Tranes, is there more risk to breakdowns due to the more complicated systems with more parts? This may also factor into my decision. Thanks for your help guys!!
  #2
Old 04-24-2009, 01:36 PM
marvin marvin is offline
i dont know about the eastern part of the country, but here in the
desert i still have rtu's that we installed in the 60's that are still
in good condition. not effecient but do a good job cooling & heating.
  #3
Old 04-24-2009, 02:28 PM
beenthere beenthere is offline
Moderator
@ stage has little bearing on life span/break downs.
Seen a lot of single standard blower RTUs that barely made it 10 years. And a fair number that didn't make it to 10 years.
A bad install can kill any brand or model real quick.
__________________
The toes you step on today, may be attached to the butt you kiss tomorrow.
  #4
Old 04-24-2009, 03:26 PM
WhoIsThat? WhoIsThat? is offline
Regular Member
Quote:
Yes, unless the parts are arranged in parallel to give redundancy. I can't imagine a consumer product that does this, though.
Even gas valve controls probably don't have this redundancy feature.
From another thread on this forum:
12 to 15 years for high end heat pumps,
7 to 10 years for builders grade heat pumps. Ocean front, 1 to 7 rears depending on brand and grade.
gas furnace 56 YO, HE (stainless) still in good shape,
AC is close to 35 YO, still the original compressor.
If you get 10 years out of air cooled equipment of any kind. You're doing well.
Midwest, we get 15-20 years out of a furnace and
20-30 out of an A/C,
20-50 out of a hot water boiler,
about 20 out of a cast iron steamer.
13 years HP,
15 to 18 for straight A/C,
18 to 20 gas and oil furnaces,
25 to 30 for gas and oil boilers.
Average is 12years for a heatpump, and
20for a straight A/C..
If you have t'storms get a surge suppressor for your HVAC control board.
  #5
Old 04-24-2009, 03:46 PM
bmathews bmathews is offline
Regular Member
I haven't seen many last more than 10 years. Most less than that. Most of the ones I work on are on commercial applications. Very few residential. Commercial are generally going to have reactive maintenance rather than preventative, very poor filter maintenance and subjected to voltage fluctuations and generally run into the ground. If I were to put anything in, it would be heat pump. I wouldn't go gas. It's outside and there is too much in the gas system to go wrong with bugs and other critters living in and around them.
__________________
I like DIY'ers. They pay better to fix.
  #6
Old 04-25-2009, 12:29 AM
aintitfun's Avatar
aintitfun aintitfun is offline
10-15 is all you can hope for
  #7
Old 04-25-2009, 10:02 AM
chadakaira chadakaira is offline
Think of it like a dog, 1 to 5 yrs pup, 5 to 10 years dog, 10 to 15 years (with proper maintinence) old dog, 15 to 20 years Asisted living, 20 plus years either dead or no longer worth a crap.
  #8
Old 04-25-2009, 10:15 AM
Regular Member
xxxxxxx
  #9
Old 04-25-2009, 10:16 AM
Regular Member
"physical life
The potential service life of an asset before it physically becomes unable to produce a good or service. An asset is often physically able to continue operating but at a cost or rate that renders it economically obsolete. The economic life, as opposed to the physical life, is most important in valuing the asset.
economic life
The period of time during which a fixed asset competitively produces a good or service of value. The economic life of an asset may be particularly short in a rapidly changing field such as electronics where new developments often render an asset obsolete shortly after it is purchased."
  #10
Old 04-25-2009, 08:58 PM
Jster2020 Jster2020 is offline
Get a new one. The stimulus plan in effect will give you a 30% tax credit up to $1500 for an air to air unit. Take advantage of it.
  #11
Old 04-25-2009, 08:59 PM
Also at that oint it's less efficient, blah blah blah etcetera etcetera.
  #12
Old 04-26-2009, 06:50 PM
Regular Member
yeah...I'm hoping for at least 15 years. (I like the dog analogy, lol)
  #13
Old 04-30-2009, 12:22 AM
superheatbob superheatbob is offline
Regular Member
The national average for all systems is 17.4 years
The national average for homeowners is that they will buy a system 1.8 times in their lifetime.
__________________
Reply
Tags
chesapeake, goodman, life, package, span, virginia, york
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
» Sponsors
» Sponsors
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
HVAC-Talk is proudly provided by:
Contracting Business MagazineAd Management by RedTyger
© 2010 Penton Media, Inc.
