I (homeowner) have a Unico system running with a 17 year old outdoor unit (straight cooling-4Ton).
The outdoor unit is probably near end of life. I am interested in replacing outdoor unit this year because of
imminent industry changeover to R410A systems next year.
Points to consider:
1) Replacing outdoor unit with new R-22 unit; more than $xK,
probably <$xK with new line set.
2) Replacing outdoor unit with new R-410A unit adds about
>$xK as the indoor evaporator coil needs swapped out
and is quite expensive.
Risk is that indoor coil breaks/leaks within a few years,
then I would have to buy a new indoor coil compatible with
R-22 (if available) but then this new coil would be obsolete when my R-22 outdoor unit reaches end of life.
What are my chances of having indoor unit catastrophically
fail before a new R-22 outdoor unit reaches end of life? Low (<20%), Med (<70%), High (>70%)
The indoor coil is probably 25+ years old.
Yet another alternative is to install a chilled water indoor coil and get the unichiller. Water won't change like R-22 -> R410 -> to whatever plus I could use that fifth ton of capacity on the hottest days without coil freezeup (I think).
If I replace indoor coil and outdoor unit, should I consider
heatpump for the shoulder seasons. I have a hot water boiler to feed a heating coil.
Your thoughts on evaluating the costs/risks?
Thanks!
Dutchglider
Reason: Removed prices
at25years old it is past the average life expectancy for a indoor unit i would replace both outdoor and indoor unit and probably go with a heat pump for the mild part of the winter season then when it gets real cold switch to hot water
