Go Back   HVAC-Talk: Heating, Air & Refrigeration Discussion > The ARPA Zone/General Discussion Forums > Residential HVAC
Residential HVAC Questions and discussions pertaining to HVAC for the home. No pricing, no DIY, please read Site Rules Register
Reply
Thread Tools Display Modes
  #1
Old 12-19-2008, 05:28 PM
raferty raferty is offline
New Member
boiler pressure dropping
got a new boiler and the pressure gauge drops erratically from time to time locking the boiler out until the manual feed valve is opened for a second and pressure is restored. Air eliminator is open and very sure of no leaks. Could this be a trapped air pocket in the system that once in a while works its way near the gauge or limit switch to drop pressure?? could use some advice
  #2
Old 12-19-2008, 05:31 PM
acmech13 acmech13 is offline
hot water or steam?
  #3
Old 12-19-2008, 05:34 PM
New Member
water...thanks
  #4
Old 12-19-2008, 05:44 PM
what kind of boiler? usually the pressure rises when its heated.
  #5
Old 12-19-2008, 05:56 PM
jwiehagen76's Avatar
jwiehagen76 jwiehagen76 is offline
Sounds like you need to call a service tech. manually feeding water to a closed loop water system is not right. By introducing untreated water continuously will cause sediment build up leading to heat exchanger failure.Boiler should be equipped with a lwco and a auto feed valve. So in the event of low water it should temporary rectify issue. You my be heading for bigger issues later on
  #6
Old 12-19-2008, 05:59 PM
New Member
its a munchkin 80m, the pressure will be good for days or weeks then out of the blue the pressure is a zero and its locked out. i'll open the manual water valve for a split second then the pressure jumps to 12psi and fires. happened maybe five times this winter
  #7
Old 12-19-2008, 06:14 PM
hvac248's Avatar
hvac248 hvac248 is offline
are you pumping away???
  #8
Old 12-19-2008, 06:27 PM
hvac_superman's Avatar
hvac_superman hvac_superman is offline
Call the installers back if it is new. May have a bad exp tank.
__________________
Buy American! The job you save may be your own.
If every American shopped at Walmart we would all live in the United States of China!
N.A.F.T.A. - No American Factories Taking Applications
  #9
heaterman heaterman is offline
Call the installer, somethings not right. I have several ideas but since this is not a DIY site, I can't help
__________________
DEM
  #10
Old 12-19-2008, 06:51 PM
was your fill valve and backflow changed when they installed it? how hard is your water? this changes everything at first u said as it ran the pressure would drop every heating cycle. Is your fill valve set properly?
  #11
Old 12-19-2008, 07:30 PM
skippedover's Avatar
skippedover skippedover is offline
You should never have to manually operate the auto-fill valve. Minute leaks will invariably allow the boiler pressure to drop over serveral weeks. The auto-fill is not responding. Call your installers back and have them change it out or properly adjust it while it's in warranty.
__________________
Never wrestle with a pig. You'll both get all dirty....AND, the pig LIKES IT!!
  #12
Old 12-19-2008, 07:37 PM
80 m is that the little black boiler. if so i just installed on the other day. replaced a hydropulse.
  #13
Old 12-19-2008, 07:41 PM
Roscoe's Avatar
Roscoe Roscoe is offline
Popcorn.......getch ya popcorn hea......Popcorn getch.a popcorn.......hea.......
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
» Sponsors
» Sponsors
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
HVAC-Talk is proudly provided by:
Contracting Business MagazineAd Management by RedTyger
© 2010 Penton Media, Inc.
