Go Back   HVAC-Talk: Heating, Air & Refrigeration Discussion > The ARPA Zone/General Discussion Forums > Indoor Air Quality
Indoor Air Quality Discussions about mold in homes, carbon monoxide, soot and duct cleaning
Reply
Thread Tools Display Modes
  #1
Old 04-13-2008, 12:08 AM
PAPAJOE1212 PAPAJOE1212 is offline
New Member
White Dust throughout the house
Over the past 4 weeks there has been an abundance of thick white powdery dust that has accumulated throughout the house. More so in the master bedroom. Any thoughts on this. I have added a air purifier (high end to correct this issue) and it does nothing but clog up the purifier. Any thoughts on this. I don't run the air conditioner often yet as the temps here in Las Vegas have not hit uncomfortable proportion yet but I don't imagine it will be much longer.
  #2
Old 04-13-2008, 09:46 AM
teddy bear's Avatar
teddy bear teddy bear is online now
Atomizing humidifiers with hard water have this effect. Regards TB
__________________
  #3
Old 04-14-2008, 04:52 PM
spotts's Avatar
spotts spotts is offline
Last time I saw this, a UV light was eating the media air cleaner.
__________________
Originally Posted by otto
Quote:
These are prime examples of why I dislike temporary repairs.
You tell a customer "I can fix it temporarily for $1250 or replace it for $12,500"
They don't hear anything in red.... "This repair should hold only for about a month until you are ready to replace the system." "The new system will run just fine and all will be happy in penny pinching land."
  #4
Old 04-14-2008, 06:08 PM
dillon2's Avatar
dillon2 dillon2 is offline
Possibly a leaking dryer vent. Could be fine lint. I find this more times than not.
__________________
Everybody has the right to be stupid. Some people abuse the privilege.
  #5
Old 04-15-2008, 11:58 PM
marlboroman marlboroman is offline
I have also seen UV lights eat up filters and cause this problem...
  #6
Old 04-16-2008, 03:04 PM
genesis's Avatar
genesis genesis is offline
Hey Spotts you in the middle of the fires in Colorado right now??
  #7
Old 04-16-2008, 06:16 PM
shrtfuse6 shrtfuse6 is offline
Regular Member
need more info is your house on a slap or a craw iv seen this happen when the pipes in the slap gets old
  #8
Old 04-17-2008, 05:18 PM
howellheating howellheating is offline
Regular Member
Ive seen it from bypass humidifiers too.
  #9
Old 04-22-2008, 12:25 PM
PikeyDawg's Avatar
PikeyDawg PikeyDawg is offline
Regular Member
Quote:
Is this a new house?
  #10
Old 04-24-2008, 10:12 AM
MechAcc's Avatar
MechAcc MechAcc is offline
Educational Committee
The high end purifier may be removing the contaminants in the air that make dust a dark color and now the staining agents are being removed and now the dust is appearing white. Just a thought.
__________________
Aircraft Mechanical Accessories Technician. The Air Force changed the job title to Air Craft Environmental Systems Technician. But I've decided I'll always be a Mech Acc.
  #11
Old 04-27-2008, 12:20 PM
options options is offline
If its a new house or you have done recent remodeling (drywall, inside french drains, etc.) then the dust is likely from those projects.
If not, 4 weeks ago did you or someone else in your home remove and inadvertantly reinstall a dirty filter backwards?
Ron
__________________
The greatest pleasure in life is doing what others say can't be done!
  #12
Old 04-29-2008, 12:56 PM
drodrick603 drodrick603 is offline
Regular Member
do you have a whole house humidifier? if so the evaporating water leaves behind minerals( which is a white powdery substance) that will go throughout the house. routine maintaince and a flush cycle can easily get rid of that.
  #13
Old 04-29-2008, 10:35 PM
cmajerus's Avatar
cmajerus cmajerus is offline
sheetrock dust, humidifier residue, new white carpeting, cocaine(jk), has this been happening for a long time or something new?
__________________
You can't fix stupid
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
» Sponsors
» Sponsors
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
HVAC-Talk is proudly provided by:
Contracting Business MagazineAd Management by RedTyger
© 2010 Penton Media, Inc.
