Go Back   HVAC-Talk: Heating, Air & Refrigeration Discussion > The ARPA Zone/General Discussion Forums > Residential HVAC
Residential HVAC Questions and discussions pertaining to HVAC for the home. No pricing, no DIY, please read Site Rules Register
Reply
Thread Tools Display Modes
  #1
Old 10-08-2007, 08:35 PM
capthomas capthomas is offline
Regular Member
Confused Lennox XC21 AC SEER Lower Than Expected?
I've had a Lennox HVAC system installed in a new home in Central Florida. The equipment is:
A/C Compressor - Lennox XC21-060
Coil - Lennox CX34-62D-6F
Furnace - Lennox G60UHV-60D-135
The Lennox literature and website advertise "up to 20.5 SEER" for the XC21. I realized that the "up to" meant that it might not be quite 20.5 based on the coil / air handler, but did not expect that the rating tag added on installation would say it is a 16.5 SEER. That's about a 20% reduction from the advertised number.
Is this a normal thing? What equipment changes would it take to get this close to the advertised 20.5 SEER?
Cap
__________________
Cap
  #2
Old 10-08-2007, 09:21 PM
BaldLoonie's Avatar
BaldLoonie BaldLoonie is offline
Moderator
Typical. Pretty rare for a 5 ton unit to have the highest SEER rating.
  #3
Old 10-08-2007, 09:38 PM
Nytefog Nytefog is offline
When paired with the correct coil/air handler and or furnace the unit has the capability or reaching "20.5" seer. Most likely the units rating with with a generic coil rates at "16.5".
  #4
Old 10-08-2007, 11:02 PM
t527ed's Avatar
t527ed t527ed is offline
Quote:
Cap
5 ton units are always the "pigs" in the efficiency line up.
only way to get the rated #s is with 2 and 3 ton units.
what you have listed is the best match available for that unit.
  #5
Old 10-09-2007, 06:41 PM
Regular Member
Thanks for the responses.
I feel more confident in the install now.
Cap
__________________
Cap
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
» Sponsors
» Sponsors
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
HVAC-Talk is proudly provided by:
Contracting Business MagazineAd Management by RedTyger
© 2010 Penton Media, Inc.
