| Commercial HVAC Questions and discussions regarding HVAC for commercial buildings |
12-19-2006, 05:23 PM
Regular Member
Anyone got any comments, good, bad, or indifferent regarding these types of distributed DX systems? Daikon, Mitsubishi, Colt, etc. are flogging these systems as the latest and greatest solution to local zone HVAC control. I have some concerns about a lot of high cost/high pressure refrigerant pipes scattered through a building in terms of risk management. They claim a higher energy efficiency, but I think a good old two-pipe water to air packaged heat pump system wouldn't be that much worse, and you're only going to be dealing with low pressure water if it leaks.
12-19-2006, 05:36 PM
Regular Member
I would rather have a ref leak above ceiling tiles than water.Almost all supermarkets are piped over head,and besides most of the time if the piping in the overhead is tight after startup it is usually trouble free.The key though is a proper startup.
12-19-2006, 10:26 PM
We have installed 50 or more and I have started up over a hundred by know. Mitsubushi only. The only problem is no service calls
12-20-2006, 09:12 AM
Member- bad email address
These type systems are only new to U.S. Been in Asia and Europe for years. As stated, proper start-up is key.
The few people I know that work on them say service calls
are few and far between. The efficiencies are due to the
variable speed compressors.
09-24-2008, 09:29 PM
Regular Member
This is the latest technology and it is not just a lot of BS. By the way, there are few failures, but you better know your HVAC before you attempt an install or service call.
09-28-2008, 08:39 AM
Do have some training and info before installing.
09-28-2008, 05:49 PM
we have done Daikin systems and find them to be trouble free. The energy recovery stuff is great and allows for even better efficiency while running some zones for heating and some for cooling. One packaged unit cannot give you the flexibility of these systems. They are very common outside the US and work well.
10-08-2008, 06:54 AM
Banned
Daikin,Mitsubishi
Quote:
We are specialized in installation of these systems....and what i gather is that you dont have a clue ..what is happening with these higher pressures maybe that is why you posted so many " smart " words
10-11-2008, 08:28 AM
Regular Member
CB magazine did a full story on this new application in their September issue http://www.contractingbusiness.com/
__________________
"when in doubt...jump it out"
10-20-2008, 05:55 PM
Regular Member
VRV off the beaten path
I don't know how we got so far off topic, but to get back to VRV technology, the stuff is great. It is not the death of chillers and package systems, only another solution that may provide better control while saving energy. If you look at the full picture, performance, longevity, low-energy consuption, ease of installation, low maintenance cost, self diagnostics, then these systems often out perform all the other technologies.
11-04-2008, 06:57 PM
Regular Member
think of it as chill water
The concept was born from Daikin in Japan 1982 and was a solution from the chiller group. They figured that they could move refrigerant more efficiently than water or air.
If the piping is done correctly it is a moot point. Just remember about refrigerant density in the space. ASHRAE 15 states R 410A at a max of 25 lbs per 1000 cu ft.
11-05-2008, 09:11 PM
Regular Member
Are you an employee of Daikin??
11-05-2008, 11:27 PM
What happens when a compressor burns out!! I would like to know how you would clean up a system that is so large in piping length.
__________________
"Blessed are the pessimistic, for they hath made backups."
Picture is of Christmas decorations from someone in Grand Rapids Mich. They only had it up for two days-causing too may accidents in the busy street next to the house!
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
