+ Reply to Thread
Results 1 to 20 of 24
Thread: Hill Phoenix
    Jan 2010
    Hill Phoenix
    (Smart Valve ) anyone servicing these ?
    You mean the Hill Phoenix SMS system.
    The Electronic Expansion valve that requires a FREE software download and an outrageously priced USB Dongle to program or communicate with?
    The same system that they're installing on their Glycol "semi-self-contained" systems, attaching the controller to the bottom of the drip pan and wondering why they burn out?
    Nope.... Never worked on one....... This week....
    Whaddya need to know?
    Sep 2006
    Chicago
    If you service these it would be wise to carry a temp sensor and a pressure transducer.
    Quote Originally Posted by dangpgt97 View Post
    I'd carry a couple transducers....
    Sep 2006
    Chicago
    Jan 2010
    Sounds like the same setup. The way I'm seeing it you have to use a IR device that plugs into ones laptop then shoot it at the possessor. This is the only way to reprogram it for a different refrigerant use. That's not what I'm after though. Was just curious if one can troubleshoot the plugins. I know the first thing I need to do with the one I'm working on is to get the outdoor unit on some type of head pressure control. Will these valves hunt like the mechanical valves ? How much is the dongle ?
    I suppose that wild swings in system operating conditions could make the valve hunt, but under relatively constant conditions, they're TIGHT! They'll run a nice, low superheat and keep it pretty tightly controlled with a minimum of hunting.
    My understanding was that the dongle was about $400. I didn't buy it, though.
    I suppose that you could troubleshoot these systems by 'guess and golly' but I've found that a laptop and the dongle make it much easier and more accurate.
    Jan 2010
    Thanks jp,
    So it sounds like you got your company to shell out the shillings for you....nice. Unfortunately this cheap a$$ is not going to do that. I'm twisting his arm just to get a fan cycling control on it. I would much rather pipe in a proper head pressure control. This reach-in is using R404a at medium temp. What should the coil temp. be running at ? I was at about 15* if I remember correctly. Hill Phoenix is showing a 6-8* superheat. I was getting a yellow/red led which is a high superheat code. Also the case is on a time clock for time defrost is that necessary ?
    Thanks VTP
    Sep 2006
    We carry a Q body kit for these gems
    California
    Hill Phoenix and smart don't belong in the same sentence, not even the same thread.
    Jan 2010
    Quote Originally Posted by Blackmira View Post
    The thought crossed my mind. But what a shame to waste all that advanced technology.
    Jan 2010
    You must be a Kysor/Warren or Hussmann guy.
    California
    Neither.
    It's just, I had recent bad experience with Hill is all.
    I like Zero Zone stuff.
  14. #14
    Jan 2010
    Neither.
    That Zero Zone stuff is quality for sure. The last one I serviced was built like a tank.
  15. #15
    Almost 100% of the new equipment we're installing is H/P or Barker. I've set up quite a few of these EEVs recently.
    Suction temperatures have been moving upwards over the past 10 years or so.
    Meat cases used to want to run at 12 degrees SST. Now, I'm setting them at 18-20SST and getting the same or better product holding times. Better designs.
    Newer case, I'd start at 18 SST or so, and see where it goes from there.
    What I'd do is measure the SH. If it isn't high then I'd either start by replacing the transducer, then the temp sensor OR, I'd do as blackmira suggested and break out the Q kit, IF and ONLY IF, the case is over 12 months old.
    Our company got burned on one where a guy did that. H/P rep walked in, looked at the case and said "You modified it, warranty void" Customer made us put an EEV back in the case. Almost all of us carry transducers and sensors. One guy in each region carries a laptop and a dongle.
    Lately, I'm tending to agree with Phase Loss. Hill/Phoenix sure ain't all that excellent on the quality side of things. Too many little details that aren't right.
  16. #16
    Meh..... I helped out on a startup in a ZZ store.
    Neat stuff, smart factory guy, but no more special than anything else I've seen.
  17. #17
    Jan 2013
    Northern CA
    Neither.
    What happened at Hill Phoenix? And zero zone, oh boy that's some junk...
  18. #18
    California
    Quote Originally Posted by Icanfixitall View Post
    Have you worked on their stuff???
  19. #19
    Jun 2001
    Michigan
    I wish the device and assembly also had DA.
  20. #20
    florida
    SMS sucks.
    Educational forums are open.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
