Results 21 to 36 of 36
Thread: New Goodman H/P defective
  1. #21
    Thanks for the replies.
    I'm willing to take my 29 lashes for this entire mess. I've been in the service business for 30 years and knew better.
    I don't know what the measured pressures were, but the installer and seller, who is also an installation contractor, agree that the reversing valve is not functioning properly. I do know that it cycles audibly and pressures reflect that.
    The system was not bought off the internet. I picked it up at the seller's location, two hours from here.
    I have a local Goodman contractor, but his arrogant attitude precludes my ever doing business with him again. In the past, I've bought repair parts from him for Goodman gas furnaces in some properties I own, but now I drive an hour to get them. I know the importance of customer service, and my business reflects it.
    I had the job quoted by a York contractor, but given the low anticipated usage in a well-insulated 2000 sq ft shop, I opted to save some money. Again, a bad decision. The York system in my home has served me well for 22 years.
    The reversing valve arrived today and it is made in China. I assume the original is, also. A topic for another thread....
    Being somewhat close to retirement age, (although I'm having entirely too much fun to quit what I do) I don't know how to address the suggestion that a retired craftsman is inept. I hope I've misunderstood.
    My original curiosity, "Are dead new systems common?" has been addressed. Again, thanks for the replies.
  2. #22
    LOL..
    Just because a contractor retires, doesn't mean he's inept.
    Bit more then one person has used that term. When in reality, the "retired contractor" only worked in the trade for a few years.
    Everything has to be taken with a grain of salt.
  3. #23
    problems with systems during first year- 90% installation- 10% equipment. the reversing valve on your goodman is manufactured by a company that makes these valves for other manufacturers too. chances are its the same valve as on another manufacturers system. and yes there can be challenges upon start up of a new system. but that does not mean you get a whole new system.
  4. #24
    Nov 2000
    Eastern PA
    Quote Originally Posted by TurboViper View Post
    Well my friend, you have not talked to the Goodman rep in your area...believe me, I know that for a fact.
    I also know who you purchased your equipment from and that you did get their information from the Internet.
    At this point I really do want you to be happy, but I serously doubt the reversing valve is your issue. If you want to have the issue resolved, call the Goodman consumer affairs in Houston (877-254-4729) and file a complaint. That way you will get the Goodman rep to look at your system. If you had had your system installed by a Goodman contractor you could have had that contractor get the Goodman rep to your place.
    The biggest problem here is your lack of respect for the HVAC industry makes you think that anyone can install equipment properly. If you want your system fixed properly, call Goodman's consumer affairs and be prepared to have a qualified HVAC technician at your home to meet with the regional Goodman rep.
    Training is important!
    Practical Training is a must!
  5. #25
    Nov 2000
    Eastern PA
    LOL..
    No one actually stated the installer was inept, but he certainly seems to have improperly diagnosed this issue. As stated, a malfunctioning reversing valve is going to usually create issues in both heating and cooling modes. A "bad" revsing valve is one that either sticks or leaks intenally (due to "sticking").
    For cases where the reversing valve is not working properly in only one mode, it is usually a problem with the solenoid or pilot tubes. Not operating in the heat mode would mean that there is power to the "O" terminal from somewhere since this reversing valve energizes in the cooling mode.
    Even the new Chinese valves we are seeing on the market operate on the same principles as reversing valves manufactured elsewhere. I have a Goodman heat pump with the same valve in it sittin outside of my home/office window.
    At the very least, we need to be having this conversation with a technician, not someone who bought HVAC equipment direct and is now claiming it was installed by a qualified HVAC tech. Let's hear from that tech firsthand so we actually have something to work with.
  6. #26
    Apparently, your investigation failed to reveal that I have spoken with Goodman's consumer affairs dept in Houston.
    Your perception of my lack of respect for the HVAC industry doesn't merit a response.
    I didn't come here looking for sympathy. That's something that should have been readily apparent from my previous two posts. Being an HVAC "outsider", I was simply wondering how common it is to have the type of failure we've experienced. I know that installation is by default going to be blamed.
    I appreciate your concern for my happiness, but I'll be pretty straightforward about it. I'll create my own happiness with this situation, whatever is required. We have a saying at the shop, "There's never enough money to do it right, but there is always enough to do it over." If this turns out to be the biggest loss I ever eat, and it already can't be, I'll do okay.
    Thanks to all who offered up help.
  7. #27
    Nov 2000
    Eastern PA
    I did no investigation at all on this particular instance. I still want to help you. If you email me (email in my profile by clicking on my username) who you spoke to I will follow up and expedite getting your issue resolved....personally.
  8. #28
    Feb 2007
    You probably don’t deal with your local Goodman contractor because of his refusal to give you constant free advice, which made him seem arrogant.
    There are easy tests any competent HVAC technician can do to see if the reversing valve is bad. If you want to replace it without knowing for sure, go ahead and have fun, reversing valves are harder to replace than compressors.
    If your valve is bad, it’s most likely someone got contaminates in the system during installation. If so, you’re going to continue to have problem after problem.
    You had the job quoted by a York contractor, and decided to go cheap. If you’re half as smart as you think you are, you’ll cut your losses, chalk it up to experience, and call the York contractor to rip everything out and start over.
    Don’t even bother calling your retired HVAC contractor friend that owned you a favor, he's probably fed up with you by now, and has decided to pay someone for future work rather than be beholden to you.
  9. #29
    Not operating in the heat mode would mean that there is power to the "O" s hear from that tech firsthand so we actually have something to work with.
    I road the installer being an x contractor.
    I'm waiting to hear what they're going to do after the new RV is installed and it does the same thing.
    I'm not allowed to tell them what wire to remove to prove that its a wiring problem. That would be DIY advise.
  10. #30
    Quote Originally Posted by bobb25 View Post
    Your ad hominem response made me laugh. Many of the folks who still do business with this certain contractor cannot stand him. I know several who won't set foot in his place. I've never asked for his advice. Not once.
    Your analysis of me failed to note the three hours I spent with a customer yesterday helping him sort out some critical choices for a project we are doing. That is time I won't be billing him for, by the way. Now who seems arrogant?
    I have spent countless hours answering e-mail questions that have resulted from the two technical books and dozens of magazine articles I've written -not on HVAC-, yeah, you got me on that one.
    I don't know how smart you think that I think that I am, but I will assure you that I am several notches shy of being a genius. It might surprise you, however, to know that I have designed more complicated electronic control systems than you'll find in a residential HVAC system. And I am smart enough to never take cheap shots from my keyboard at people I don't know.
    Since my original mea maxima culpa seems not to have been sufficient, I'll say it again: I made a mistake. To those who love Goodman, I apologize. I did not intend to bash them or their equipment. After some reading on this forum, I see there is tremendous brand loyalty and equal brand hatred. I should have left out the brand identification and my question could still have been answered, sans the controversy.
    RoboTeq, I appreciate your offer. I'm not planning to do anything to the system at this time, and your (and others) belief that the valve is not defective will be given large consideration.
    Thanks, and I wish you all well. Goodbye.
  11. #31
    Nov 2000
    Eastern PA
    Good luck. My offer remains open. I absolutely can help you.
  12. #32
    Jul 2001
    Raleigh NC
    I disagree that its harder to replace a reversing valve than a compressor. I don't mind either but the changeover valve is a whole lot lighter if you ask me. You just have to know the tricks to making it easier to get the old one out so you can clean up the tubes to use in the new valve. Heat sink paste and damp rags and you got it whopped.... No heavy lifting involved. Robo, you seem to be awfully giving in this particular instance. Not that you aren't always willing to help but more so this time. Just my observation. Excuse me if I am out of line but my neighbors AEPT030 with the Chinese Contactor burned out the CPLT24-1B's Control Transformer and they called crying about no heat and I just got them back up on my Sunday evening. I knew I would end up having them call me at night If I put their unit in and here we are. At least I got me some homemade sausage out of the deal and looks like I get a 50 dollar labor allowance from Goodman for the contactor. How about the burned up Transformer??
  13. #33
    leland nc
    since you have alot of experience with electronics and control wiring then trace your wiring from stat to air handler to condenser.
    let us know wat you find. follow the schamatic
    or take Robo up on his offer. It is you best route
  14. #34
    Nov 2001
    east kansas
    What else did you have installed? Was it a complete system?
    Beware of advice given by some guy on the Internet.
  15. #35
    Nov 2000
    Eastern PA
    Quote Originally Posted by nc hvacman View Post
    Any failed part is covered under the warranty no matter what made it fail (within reason).
    My willingness to work with a contractor to help the OP out is that he is in my territory and I can actually do something hands on with this one.
  16. #36
    Melbourne,Aus
    That really depends.!!!!! if you are in charge of Warranty issues then you will make sure that if a claim comes in it is actually Warranty....Warranty cost's just push up the bottom line of the manufacturers product which in turn makes the units or equipment just cost more.
    Not that this is my job but as long as companies are outsourcing to overseas companies to get cheaper parts then things are going to fail. I would like to think that most A/C units are built to a quality standard but the people who make them are only human and if they have the Shi$s on with the company on the day that they are manufacuring a unit it is going to turn out crap!!
    We all hang crap on the manufacurers when a peice of equipmeny fails but that is up to the workers who either build that piece of equipment or put it together.
    I would hate to be a manufacturer as your the bad guy when something fails..!!!!!!
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
