+ Reply to Thread
Results 21 to 36 of 36
Thread: Tool to measure superheat, subcooling?
  1. #21
    On a bull named Foo Manchu
    Quote Originally Posted by Grayline View Post
    I used The testo 570 side by side with my Field piece ssx34 one touch between SH& Sc and saw a big difference in speed and the testo was always 5-7 deg off.
    But I do Love my 570 for everything else!
    Are you saying the 570 is less accurate than Fieldpiece SSX34?
  2. #22
    Mar 2012
    Finland
    I use Fluke 54 II B and it is good..
  3. #23
    Apr 2013
    Winter Park, FL
    I use a Fluke 116 meter with fluke pipe clamp and do the SC/SH calculations manually. I like the pipe clamps better than the velcro wrap sensor for smaller diameter pipes.
  4. #24
    Jan 2013
    More like your FP is off than your 570. How long you had the 570 and how often do you calibrate your FP temp clamp?
  5. #25
    Oct 2009
    aiken s.c.
    Is the fieldpiece ssx a good investment?I have been thinking about buying one but I have not ever talked to anyone that has one.
  6. #26
    Jan 2013
    Quote Originally Posted by aikenite View Post
    It's ok, but you would be better off with an SMAN 3 or an SMAN 4.
  7. #27
    Oct 2009
    aiken s.c.
    I have used the 116 too but I hate having to use the adapter with the pipe clamp.I have had 2 to pull apart when I went to take the clamp out of my meter.I do try to take care of my equipment.Have you ever had this happen?
  8. #28
    May 2013
    I have an ssx34 by fieldpiece. It was 250 when I purchased it 2 years ago. Now was it worth it. Still not sure. There's nothing it does that I wasent doing with my gagues and a thermometer and tape. It does make things a bit quicker and some what more convenient but the price tag is a little high for this minimal convenience. Put it this way, the batteries died last month and I haven't changed them.
  9. #29
    Mn the state where absolutey nothing is allowed
    fluke 116
    have a care using a fluke 116 for temperature. even fluke admidts its only good for general measurements.
    the internal reference thermocouple is buired in what fluke cals a thermo-isolation block to stabilize the readings against the meter body temp changing. but that same thermo-isolation block greatly slows the temp stabilazation when you need it. it also has no emf shielding .
    the reality is the meter body, the thermocouple and that stupid adaptor all need to be at the exact same temperature or else the reading is inaccurate.
    you really need a meter that is designed as a thermometer such as a fluke 52/54 series or a cooper that uses thermisters for an even more accurat albeit slower response. the top 3 DRSA manufactures employ decent thermometer technology
    my boss thinks its possible to repeal the laws of physics
  10. #30
    I don't see the purpose of a stand alone SH/SC calculator. I'd save the money and do it manually or throw a little extra with it and get a drsa that will do that and more.
  11. #31
    x2
  12. #32
    Mar 2009
    Mid-Mo
    I had one when I first started and it was very helpful. Ended up giving mine away to one of the new guys now that I have the formula, I don't really need it anymore.
  13. #33
    Oct 2012
    Ohio
    I use the thermocouple that came with my uei meter and a $1 clamp from Harbor Fright.
  14. #34
    Aug 2009
    Maine
    I think there is an app for that.
  15. #35
    Oct 2007
    A One dollar clamp? You must mean one of those plastic clamps to hold the thermister lol.
    I have UEI, and they work great. I did buy 2 fluke thermister clamps on ebay though. Works great when working on 2 evaps at the same time
  16. #36
    Oct 2009
    aiken s.c.
    I believe You might be on to something.With the bead you're getting a pin point reading and the clamp would insulate it.I have been thinking about this ever sense I read it and I am definitely going to try it.Some people are always thinking! What type of clamp do you use?A bar type or squeeze type?
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
