+ Reply to Thread
Results 1 to 20 of 36
Thread: Why I Always Check Disconnects
    Apr 2012
    Paper Street Soap Company
    A 50 Amp 3 pole 600 volt disconnect on a Carrier RTU Friday.
    Apr 2012
    winnipeg
    man ...that is just wrong....thank goodness you checked...
    Quote Originally Posted by Six View Post
    on a Carrier RTU...
    Those things are hacker magnets wherever you go, for some reason.
    I don't always open the disconnect, but I always check with my meter, and verify it with something live first.
    Oct 2011
    between here and over there
    GD. They could have at lease left a note on the unit..
    NC
    Found the same thing on a residential unit a couple of weeks ago. It was actually a fused disconnect that 'HO's cousin' said was bad.
    Mar 2009
    Mid-Mo
    Every time I see this I cringe and think how bad that would hurt if you didn't check that first. Really sad considering they aren't that hard to changeout or all that expensive compared to someone's life.
    NC
    You have to always check before you put your hands in. I've run into units that were fed from two different power sources.
    May 2012
    Upper Michigan
    A guy who worked for the company I work at got fried by 480, eye balls melted out of his head I guess. The disco was wired wrong. I don't know the whole story but that's what I remember.
    Apr 2012
    Its one of the first things I check just to insure there are no loose connections, burned wires or bad terminals,etc.
    Part of my general inspection that I've been doing for years on equipment that I've never run across before. It's both CYA and a solid service practice.
    If we get the PM contract then it's part of my quarterly PMs.
    Thing is I'm in the habit of inspecting the terminals and wires that it actually took me a couple of seconds to realize what the hell I was looking at.
    Showed that pic to the store GM and he rolled his eyes " I know who did it " and he walked off in a huff.
    Took a whole 30 minutes to go down the street and pick a new one up from a electrical supply. Well a bit longer because I had to make a stop at one of three local Carriers to get a Condenser fan motor, blade and cap.
    I don't get it. Lazy techs I guess.
    Apr 2012
    There was a guy in Houston that was working on a AHU starter in a building mechanical room.
    Never got home never called in after the job which was a late day service call.
    They found him the next morning still wedged between the AHU and the starter.
    Supposedly it was a tight area and he was hit and it cause his heart to go into defib.
    Couldn't get out fast enough I guess.
    May 2012
    Upper Michigan
    You always have to be thinking in the trade, one wrong move and your toast, exactly why HO's shouldnt touch there equipment.
    Apr 2006
    Barrie Ontario
    Went to remove a panel cover once to put in the breaker for the unit we just put in as I was backing out the screw it blew in my face put a nice size hole in the panel cover. Guess the sparky that wired it in originally left the access wire looped in front of the cover screw ( before the main breaker) and over the years of going in and out wore through the caseing it was a nice surprise. Was lucky I was only blinded by the flash for twenty minutes and nothing more.
    For some reason I learn more with my mouth shut
    May 2012
    Upper Michigan
    When I was really green I was with a guy working in a timer for parking lot lights 480 I think. We got I'n the electrical room and noticed the cover across the room, didnt think much of it, it's open to maintenance and we thought they took it off. When the guy tried the timer I could hear it, I can't explain the sound but I knew nothing good was going to happen, then BOOM the thing exploded, I ducked just In time not to get burnt. Pretty freaky.
  14. #14
    Jan 2010
    The hack could of at least broke the handle off as a heads up.
  15. #15
    Yes Mr store-owner, I can get your unit working for $100. Hack proceeds to the roof and by-passes the disconnect. Store-owner is happy cause he has cool air and a low bill... next guy gets the shocking truth... pun intended.
    GA-HVAC-Tech
    GA's basic rules of home heating and AC upgrades:
    *Installation is more important than the brand of equipment
    *The duct system keeps the house comfortable; the equipment only heats and cools (and dehumidifies)
    *The value of comfort, over the long term; leave economic choices behind!
    Choose your contractor wisely!
  16. #16
    Sacramento area
    Arrow We cannot be TOO careful!
    Quote Originally Posted by Tech Rob View Post
    I have a friend, who fortunately escaped injury, who was doing pre-start-up checks inside a larger air handler. He had verified with his meter the power was off. He had just finished working at the belts & sheaves when the blower began operating while he was inside the unit.
    This new rooftop unit was a replacement for an old unit. The on-site maintenance guy had bypassed the disconnect and he had the circuit breaker inside the building turned off. Then the maintenance guy turned the breaker on, not aware that someone was inside the new unit.
    I'm still learning this trade.
  17. #17
    Quote Originally Posted by uhPrintUs View Post
    Tag it... better, lock it...
    GA-HVAC-Tech
  18. #18
    Jan 2010
    Perfect example of when panel lockouts should be used.
  19. #19
    May 2012
    Upper Michigan
    Lock out tag out
  20. #20
    Oct 2007
    Huntsville, AL
    I remeber when I was green I was changing out a 480v unit at a church I killed the disconnect (didnt check the unit for power) started un-wiring the old unit when I pulled the first wire out it rubbed against the unit and sparks flew and I almost sh*t myself. I opened the disconnect and sure enough it was broken..... That is when I learned to always check units before working on them.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
