+ Reply to Thread
Results 1 to 20 of 22
Thread: Modine unit heater?
    Modine unit heater?
    Working on Modine u/h today m/n PA300A, with standing pilot. On a call for heat the unit fires but as soon as the fan kicks on the gas valve looses power and I loose flame. Any after fan shuts down it repeats cycle again, flame on, delay fan on, flame off etc. No schematic so not entirely sure wired correctly.
    michigan
    How old is this unit. Did you check the heat exchanger? Not familiar with this particular unit, but I wouldn't think there would be that much different about it. Hi temp limit? Stack switch?
    Jan 2011
    Boston, MA
    Ok, your losing power to the gas valve. Where are you losing it before the valve?
    Does the pilot stay lit?
    (rhetorical quesitions)
    Dec 2012
    columbus, OH
    Maybe someone come in and wired the fan in series after the transformer and its stealn its juice.
    Jan 2010
    Check your thermocouple millivolts.
    up in the hizzy
    Quote Originally Posted by iceage View Post
    seems like a weak limit, jump the fan control to get the fan to run before the burners fire, see if it runs that way, if it does, fan switch or the limit are the problem.
    Salem, WI US
    I'm thinking the limits are not wired correctly as well.......
    Oct 2011
    Chicagoland Area
    There's realy not much to that unit. Should have a maunal reset spill switch, one, possibly 2 limits. One being a 3 wire limit which is where I suspect the problem lies. What was your gas pressure?
    Why is it that those who complain the most contribute the least?
    MONEY CAN'T BUY HAPPINESS. POVERTY CAN'T BUY ANYTHING
    Mar 2001
    Ilwaco, Washington
    Is this one that has a time delay fan switch wired in parallel with the gas valve? Could be the 24 volt heater on the time delay is dead shorted, and pulling valve off. Does pilot stay lit?
    One way to outthink people is to make them think you think. They'll think you're not really thinking what you're trying to get them to think you think...........
    Quote Originally Posted by uniservice View Post
    . Yes pilot stays lit
    Unit is from 1975, one limit 3 terminals on it, no cracks on exchanger,pilot always stays lit. I have 120v at either side of limit when it opens, longer than usual amount of time before fan comes on after burners, bad delay timer maybe, I was told this particular timer is obsolete and a sequencer would be needed. No schematic but wonder if 120 is normal for these older units at limit. Gas valve 24v
    up in the hizzy
    Look a little bit closer1975 and no cracks on the HX?, unless they didnt use it for the last 20 years. the limit probably breaks the primary for the 24v transformer.
    Dec 2012
    columbus, OH
    Quote Originally Posted by valdelocc View Post
    Prolly cast iron
  14. #14
    Oct 2009
    Raleigh, NC
    I have a Modine unit that has been heavily used since the late 1970's. The heat exchanger is fine. It is basically just 10-12 oval tubes that the fan blows over.
  15. #15
    up in the hizzy
    Quote Originally Posted by MicahWes View Post
    Well, a furnace in NC runs twice a year
  16. #16
    Stupid question but, if limit breaks transformers primary 120, what powers fan?
  17. #17
    Dec 2012
    columbus, OH
    the limit is wired through the tranformers circuit
  18. #18
    west burbs,il
    Sounds a little goofy to me. Usually you see the limits and roll outs wired series in low volt. It may have been Jimmy rigged. Sometimes these modine units,especially older used a gas valve that had thermostat built in with probe and the blower cycled on and off when call for heat without delay off for blower. So basically that switch is probably a limit switch for low volt but somebody tried wiring blower line voltage to it thinking it was auxiliary blower switch.
  19. #19
    Jun 2012
    I had a modine of that vintage and could not get parts from suppliers. I do not know what the issue was but I found some greenhouse websites that had good pictures, schematics and numbers. I pulled the modine part numbers from the site, called my supplier and gave him those numbers and he found the parts. It was like his information did not go back far enough. Those old moodines are tough... I have not seen many cracked compared to other brands of similar vintage.
  20. #20
    Dec 2012
    columbus, OH
    Ive seen the limits wired both ways. Either turning off the trans former or just the gas valve, if the limit shuts off the primary side their is usualy a jumper wire from the input of the fan switch to the limit. Shouldnt be to hard to follow the wires. Let us know when u figure it out.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
