Results 1 to 12 of 12
Thread: Nortec Humidifier
    Central Pa.
    Nortec Humidifier
    i have a Nortec Humifier Model# NHMC100 giving "Excessive Current Error 1" code. Checked voltages, 460 3 phase unit, wire connections etc. Replaced the cylinder, checked the conductivity of the water and everything. Still getting the alarm and lockout. Any help would be great.
    Baltimore
    Do you know what the current is that it is pulling when calling from humidty? what is the conductivity of the water? I have has some issues and It was a problem with the board. Not sure if any of this helps?
    My job is to send a man thats wants big money for little effort to a customer that has a problem but doesnt want to pay for it!
    Panic caos and disorder my work here is done!
    ottawa canada
    Call 613-822-0335 and ask for tech support .
    I"m not a service tech, I’m retired ….I used to be a thermodynamic transfer analyst & strategic system sustainability specialist
    Is the unit draining OK? Or is the the drain stuck with dirt making it drain all the time?
    I had that problem this winter but I think it was giving a different alarm.
    SF Bay Area
    Read Grahams' post above.
    If this is a regular PM for you, hopefully the operating amps are recorded somewhere on the job site, in your notes, or maybe there is another humidifier on site that you can compare the current amp draw against?
    If the humidifier is located outside, moisture can form inside the control cabinet on the control boards and cause nuisance trips. I've only ever seen the current error 1 caused by poor connections or a plugged cylinder drain.
    Central Pa.
    This unit is inside an office building. Conductivity is 70 micromhos ( a little low i think). Each leg is pulling 23-25 amps. On start up the unit will call for 100% demand then the drain solenoid will open for about 3 seconds. It will cycle this way 6 or 7 times, then it seems to be ok. I'll come in the next day and it is off on alarm again. I have a new drain valve, i am waiting for a new fill valve. These items i was told to replace by tech support.
    Mar 2011
    NORTEC 100 Humidifier
    I am thinking about installing 4 new NORTEC NHTC-100'S in our facility. Does anyone have any opinion about the Pro's and Con's with this humidifier.
    Jul 2001
    Canada
    J U N K , have 18 on 1 site and nothing but GLITCHES , customer is slowly replacing them
    Jun 2010
    U.A. (upper Alabama)
    Quote Originally Posted by Truck43 View Post
    Are you sure you received the right voltage tank, and not a 230v. Also, is it for sure draining to get rid of the hard water? Hard water equals higher conductivity which equals higher amp draw.
    Mar 2011
    Control Guy
    Thanks for the reply. I've been hearing the same thing from other serviceman.
    Nov 2010
    you need to keep up on the maintenance ,you can go through bottles pretty quick if you have hard water. Install an RO supply if possible it helps.
    michigan
    I have serviced a NHMC200 several times. They are very touchy. You are supposed to clean the drain and fill valve every cylinder replacement. These humidifers are nice when they work but seem to break down more often then not.
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
