De nada and you're welcome.
Thanks much appreciated
I'm using a web /jace600 with bacnet over ip and have the second port enabled with the ip address of the Daikin bacnet box 192.168.0.1 which is the default ip address
I can ping the Daikin box directly through the pc however the Jace can't discover anything when connected in!
All I want to see weather bacnet is enabled in the Daikin box and if so then the problem possibly is with the jace.
So a start is to see with this software if bacnet is enabled??
Thanks again
Regards
Stan
Ok, what's the IP address of the Jace? It will have to be 192.168.0.X if the gateway is left at default IP of 192.168.0.1 without enabling the gateway as a foreign device.
If it is on a different subnet, say 192.168.1.1, foreign device will have to be enabled inside the gateway and this IP address must be put in so the gateway can send out a request to be added to the BBMD foreign device table.
BACnet does not need to be enabled. As long as the battery backup switch is turned on and it has an IP address, it is ready to rock. Is the VRV system already connected to the gateway? If not, you will get no points.
Pres
Please for the love of everything that is holy send me the setup tool too.
Getting this from Daikin has proved to be more difficult than pulling 5 girls home from an FHM event.
Thanks in advance. my email address is in my sig
Is there any chance someone could send me SetupMS3? I can't get a response from Daikin and really need this tool. Thank you.
threefiddy, check your mail.
Pres
C, add an email to your profile.
Pres
C, check your mail.
threefiddy, my e-mail bounced back. Not sure what the problem is.
Pres
Is there any chance someone could send me SetupMS3 please? I have to change to default IP address for it to talk to our BMS.
Thankyou in advance.
Found these forums by looking for this tool.
Could someone also forward me the setup tool setupms3?
Email Address Removed
Last edited by Chris_Worthington; 09-05-2011 at 08:28 AM. Reason: Email Address Removed
Aloha all,
Can someone please send me a copy of SetupMS3? Thank you in advance.
Mahalo,
Rich
Working on my second DBACS.Can someone please send me a copy of SetupMS3?
Any chance someone can get me a copy of software?
Daiken programmer is away and we set our network on a .3 subnet, causing conflicts with the DBACS gateway and BMS
no Setup MS3 = bad!
Anyone? Really need this software asap! SetupMS3
Volgarixon just send you a copy of the specific software, hope this help
hi all, if someone could do me a huge favour and send me through the setupms3 app, i would be forever grateful.... Cheers
The same exist for you Nickh,
