That's the first isolator I've seen that looks like that. All the ones we use are braided.
Found this just 10 days after a repair on a 5' section 4 1/8" suction line going through the ceiling. It's an R-22 system. 2nd picture is the wall facing the unit. Needed 3 gallons of oil as well. Third and fourth pictures are the "original" problem...condensor making noise...mmmm...where's the missing fan? Oh, here it is, in the condensor coil...still running!
How much gas did it loose?
Knowledge is knowing that a tomato is a fruit. Wisdom is knowing not to put it in a fruit salad.
650 lbs each time.
is that the oil on the side of the bldg???
Have tools and gauges, will travel.
RIDGID|YELLOW JACKET|UEI|TESTO|STANLEY|CPS|VETO| KLEIN|MILWAUKEE|MASTERCRAFT|
That would be a great place not to be when that launched.
Is that a factory, OEM installation of the vib-a-sorber flex tube? Is that a Carrier Condenser??
Factory job, Federal Pacific condensor, Carlyle compressor. Very old unit, maybe 18-20 years?
A smooth sea has never made a worthy mariner
English proverb
wow. at first sight i thought that was one of those copper flexable pipes you would use on water heater lines. good thing you weren't around when that thing went off
RTFM!!!
who buys the 650 pounds? Jeez
Whats up with the big 5 gallon bucket of oil in the picture?
English proverb
Customer on this. Best I can tell is that the dirty coil, broken condensor fans and years of neglect finally caught up. The vibrasorb may have gotten a little too hot when it was originally installed and was weak. I'm not sure what the head pressure was when it let go but the HP was set at 300.
English proverb
