Results 1 to 7 of 7
Thread: NORDYNE heater elements glowing red hot when thermostat set to off.
    Jul 2011
    Nordyne E2EB-015HA elements are coming on when the thermostat is set to off or even set to A/C. It glows red hot for a few seconds then the limit switch kicks it off, then on again and so on.
    I didn't see any broken or burnt wires. The A/C works fine but the heat is mixing with it. This is in a mobile home, and the thermostat is a digital DICO simple comfort 2010. Does anyone have any experiences with these units? Please help!
    Get a tech out. We had a Nordyne heat kit nearly catch a furnace on fire couple weeks ago. Turn the breaker off til it is checked.
    SW FL
    Quote Originally Posted by srryan1 View Post
    Please help!
    GIGANTIC HAZARD
    XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    I have vivid memory of flames coming out of heater coil at an industrial facility.
    IT HAPPENS .. AND IT CAN HAPPEN TO YOU.!
    Designer Dan __ It's Not Rocket Science, But It is SCIENCE with Some Art. _ _ KEEP IT SIMPLE & SINCERE ___ __ www.mysimplifiedhvac.com ___ __ Define the Building Envelope & Perform a Detailed Load Calc: It's ALL About Windows & Make-up Air Requirements. Know Your Equipment Capabilities
    Northeast Ohio
    Turn the breaker to the unit off and call for service. (It's not the thermostat)
    DEM
    Jul 2011
    I did but cant run the a/c now. Everyone is closed around my area.
    SW FL
    Lack of A/C is not an issue ... burning down your mobile home is known as A CATASTROPHE.
    Jul 2011
    Update i tested the sequencer and it was bad replaced it and fixed the problem.
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
