It can ice up in either case. The evaporator coil runs colder than 32 degrees F. The cold coil attracts humidity to it. The only time it gets a chance to thaw out is when the box is down to temperature and the compressor shuts off. If the door is left open too long or the gaskets are bad, the compressor will run too long without enough resting time for it to defrost itself.
