Results 21 to 40 of 60
Thread: Help in Florida replace AC system need suggestions
  1. #21
    Sep 2012
    Can someone please tell me if this good HVAC system . I live in ft myers Fl (HOT) . I currently have a 3.5 ton, 13 SEER Rleem that is 10 yrs. old.Crazy electric bills No heat pump, just heat strips. house is around 2100st cement block ,3 /2 /2
    I just got quote from a company for a Trane 3.5 ton (XB14 model 4TTB4042E1) with a matching Hyperion air handler (model CAM5AOCH2M31). Honeywell Pro 8000 Stat ,10KW heat strip and they are throwing in a UV light ... I was going to ask them to throw in a 4 inch media filter cabinet too
    Also come with 10 yrs parts and 10 yrs labor .... Service /Sale guy told me labor warranty would be though Trane... So I can call any dealer to fix unit. If I didn't call them .. Is this true ?
    AM I purchasing a good system. This there any upgrades I should ask for ?
    Like media filter ?
    Heat pumps ?
    Dual heat stripes?
    Different stat ?
    Am I missing anything ? They are going to be using all my old drain lines and refrigeration piping too
    I value everyone input
    thanks in advance.
  2. #22
    Jun 2001
    I'd be looking at a heat pump instead of regular heat strips for the winter.
    A heat pump gives 2-3X the heat vs. heat strips for every watt used.
  3. #23
    SW FL
    When it does come time to replace, consider a heat pump if you live in an all electric home.
    You do NOT need to consider a heat pump in Ft Myers/ Cape Coral.
    I know my heat strips do not come on even once a year most years.
    Exception was 2 years ago for part of January.
    Did you get service or quotes from the firms I recommended in my e-mail to you the other day?
    I wouldn't consider a Rheem unit if the first one is ACTUALLY dying after only 10 years.
    Designer Dan __ It's Not Rocket Science, But It is SCIENCE with Some Art. _ _ KEEP IT SIMPLE & SINCERE ___ __ www.mysimplifiedhvac.com ___ __ Define the Building Envelope & Perform a Detailed Load Calc: It's ALL About Windows & Make-up Air Requirements. Know Your Equipment Capabilities
  4. #24
    SW FL
    Quote Originally Posted by captgene View Post
    Can someone please tell me if this good HVAC system. I live in ft myers Fl (HOT) .
    I have a 3.5 ton 11 year old 10 SEER Armstrong unit for a 1800 square foot residence in Lee County.
    Electric bill is about $50 - $80 / month higher than Spring bills for 5 or 6 months a year.
    Annual service agreement from recommended firm includes service twice a year.
    I can even reccommend the honest, qualified, experienced, good natured service tech you need to request.
  5. #25
    SW FL
    York might be a good unit, but I don't think there are too well represented in SW FL.
  6. #26
    SW FL
    the 13 seer units quoted all come with 10yr part and only on year labor.but If I depend additional $ I can get 16 Seer unit with 10 yr labor too.I have email the dealer listed on this website in m area to see about a quote .there is only one company listed for my area of Florida
    I think there are more than 500 mechanical contractors in SW FL.
  7. #27
    Jacksonville,Fl
    I was a York dealer a few years ago, I had bad luck with the condenser coils (commercial equip). Not a good fit for the coastal regions.
  8. #28
    Sep 2012
    Thanks you all for the suggestion and comments very helpful info. I am leaning toward Trane.. Please somene or Trane dealer please answer the questions below.. Thanks
    Like media filter ?
    Heat pumps ?
    Dual heat stripes?
    Different stat ?
    thanks in advance.
  9. #29
    Jun 2001
    I'd go for the heat pump and media filter. The heat pump will cut your winter heating costs in HALF compared to electric heat strips. The media filter will greatly extend the time your a-coil gets dirty/clogged which is the death of many systems. A-coils are labor intensive to get to and are rarely cleaned over the lifetime of a system.
    Be sure the ductwork can actually handle 3.5 tons of cooling, if not install a smaller system or fix ductwork. You can only get as much cooling as your duct system will deliver, installing a larger condenser than what your ductwork can handle just wastes power. Ductwork repairs are also labor intensive and rarely get done.
  10. #30
    Sep 2012
    Update
    I received a quote this evening from another large local company. The salesman was the owner. I always like when owner is involved.
    Quoted
    18 SEER Trane XL20i 4TTZ0048A100A ,TAM8AOL8V41CA Hyperion air handler with media cabinet ,10kw heat , TCON 900 AC 43UA stat 12 yr parts ... Labor install permits ,
    $1000.00 Trane Rebate
    ______________________________
    Total with one yr service and 2 yrs labor
    $ for additional 8 yr labor
    This gentleman mentioned new building code included
    Float Switch safety control
    secondary drain pan
    Blower door Duct leakage test
    load calculation
    Plenum modification sealer with mastic ???? He mention they have to pressure test all vent /returns for leaks and any found leaking would cost $ to seal. Is this a scam or normal charge ?
    I have 22 vents and don't want to get told I need to seal all of them at additional $ each
    Please advise
  11. #31
    captgene,
    I removed the pricing from your post.
  12. #32
    Jun 2001
    Why an A/C with strip heat vs. a Heat pump? Your annual energy costs would be lower with a 13 SEER heat pump vs. the 18 SEER A/C with strip heaters.
  13. #33
    SW FL
    Lightbulb L. O. L. the South is WARM
    NOT !
    One does NOT need to consider a heat pump in Ft Myers/ Cape Coral.
    NO heating is ever needed
    ... I know my heat strips do not come on even once a year most years.
    How do I know? Leave t-stat set on cooling or flip the circuit breaker.
  14. #34
    Jun 2001
    NOT !
    Wow, never use heat? If that's the case why have the heat strips at all? or do a 5KW heat strips just in case it's cold? But yeah, if it never gets cold a heat pump is in fact useless. Design temp is 44, which is one of the highest in the nation, even higher than many in Florida. Summer is only 92, 4 tons of A/C for 2200sqft sounds like a lot of cooling for a relatively low design temp.
  15. #35
    SW FL
    Exclamation Know your bin temperatures ( CDDs and HDDs)
    Summer is only 92, 4 tons of A/C for 2200 sq ft sounds like a lot of cooling for a relatively low design temp.
    Below 45'F about 40 hours a year I believe would be typical [except for January 2010 it was less warm (colder, if you will)]
    So, strip heating is used, about a $60 (?) option.
    They don't call it the sub-Tropics for nothing.
    Guess what _
    Typical
    ___ Wall R-value = 5
    ___ Glass R-value = 1 (Of course, the limited differential temperature in the summer is < 20).
    ___ Clear, single pane (or pain) glass is frequently used, so SHGC = 0.88
    ___________
    ___ kinda wierd, but Definitely TRUE!
    _______
    2,200 square feet with SHGC of < 0.5 would typically be ~ 3 tons.
    January 2010 might happen once in ~25 years in SW FL.
    http://www.wunderground.com/history/...q_statename=NA
  16. #36
    Update
    Quoted
    secondary drain pan
    load calculation
    Please advise
    Blower door tests are always a good thing you don't have to seal the ducts if you don't want to but at least you will know they are there and know where you can improve the efficiency of your hvac system and home. It wouldn't be very smart to put a 20 seer hvac system on a leaky duct system because leaky ducts will lower the actual seer down to considerably. Most homes I've tested the ducts leake from 20-40% of the capacity of the system and loose at least 3 or 4 seer points because of the leaks.
  17. #37
    Jun 2001
    Guess what _
    Typical
    ___________
    _______
    That's just crazy, it seems like the OP would be better off spending money on decent insulation instead of a 18 SEER HVAC system !!
  18. #38
    SW FL
    What's the BTU/hr improvement if it's 88'F outside and 78'F inside for a 50' x 40' House with R-5 compared with R-10.?
  19. #39
    SW FL
    Hi AC professionals
    I been reading this forum today trying to educate myself .....Its great reading this info but confusing.... He is my current situation. I have a 10 yr old Rleem 13 seer 3.5 ton single stage air handler in garage ..
    My wife has been complaining about our electric bill since we moved in 2.5 yrs ago.
    My current unit when working cools the house (2200ft) fine but burns $220.00 plus per month in AC power ...
    BTW I am located in SW Fla about 5 miles from the gulf of mexico in Cape Coral ...Thanks in Advance ......
    Biggest driver of high electric bills is t-stat < 76'F.
    72'F might increase bills upto ~ 70%.
    It's normal for A/C to run constant from noon to 6+ pm for 140+ days a year.
    20 A seems more like a 10 SEER 3.5 ton unit than 13, But I don't have the model #s nor the specs for a particular Rheem unit.
  20. #40
    Jun 2001
    I don't buy into the whole high SEER saving that much more on power bills. EER is about the same from 15 SEER and up. If you oversize the high SEER unit (most high SEER installs are oversized) your high rating just went out the window.
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
