+ Reply to Thread
Results 1 to 20 of 26
Thread: Help on a 1980 carrier
    Jan 2013
    I have a carrier unit that is giving me trouble. When the power is applied the inducer motor turns on and the spark for the pilot begins sparking. After the pilot lights the burners come on and seem to burn fine however they only stay on for ten seconds at best. I am stumped because I have already put in a new gas valve, three wire pilot assembly and rollout switch. I am writing asking for advice seeing as I am still fairly green in the field. I also dont want to keep throwing parts at this unit. Also customer doesn't want to replace unit at this time.
    NE wisconsin
    Keep throwing parts at it, you will have a new furnace one price at a time.
    Jan 2013
    California
    32 year old unit? I hope you performed a safety inspection on it before you took on liability for it. You touched it, now you own it...
    Jan 2013
    I looked it over before working on it and I know that there haven't been any issues with safety in the past. This unit is in my house and due to throwing $ into it I don't have the money to put in a new unit. It's pretty sad that I can fix others units but I can't figure out my own.
    Did you check the heat exchanger for cracks?
    butler pa
    pressure switch ok ?
    Jan 2013
    That was my next option. I know it should have been done first but it is cast and the high limit isn't tripping. Any other ideas?
    Jan 2013
    Pressure switch working properly
    Oct 2011
    Chicagoland Area
    Why is it that those who complain the most contribute the least?
    MONEY CAN'T BUY HAPPINESS. POVERTY CAN'T BUY ANYTHING
    Jul 2010
    wisconsin
    Quote Originally Posted by tmryan1012 View Post
    I looked it over before working on it and I know that there haven't been any issues with safety in the past. This unit is in my house and due to throwing $350 into it I don't have the money to put in a new unit. It's pretty sad that I can fix others units but I can't figure out my own.
    I thought you saidthat customer doesnt want to replace the furnace, are you the customer or the tech or both?
    Oct 2011
    Chicagoland Area
    Quote Originally Posted by tiger man View Post
    Or neither....
    Jan 2013
    I am both but I regularly work on commercial units
    Aug 2011
    Ontario
    Why not ask some of the guy's you work with.?? Or throw it around next time your at the supply house.?? DIY ??
    There is no bad beer, some just taste better than others.
  14. #14
    I'm not following how the pressure switch being "cast", and the high limit "not tripping" are related?
    anyway..........
    be sure you test it (the pressure switch), before you replace it. Remember, a VOM and manometer are your friends.
  15. #15
    Dec 2011
    Twin Cities Minnesota
    I had this same issue last year. system may have been running this way for years. I too replace and checked everything,and was also working with "Tech support". I finally advised customer to get an authorized Carrier Dealer tech to take a look at it. He called me back a few days later to a bid on a new furnace..,he said they could'nt figure it out either! The moral of this story.,5hours labor..,3 trips..,did not make a penny! And the "Bid" didnt get it! Good Luck!
  16. #16
    Quote Originally Posted by rundawg View Post
    anyway..........
    I think he means the heat exchange is cast. And since the high limit is not ripping he didn't check the HE.
  17. #17
    Jan 2013
    Well I think my plan of attack is to recheck the pressure switch again and recheck the high limit switch again. Im also going to pull the blower motor and control board so I can slide inside the bottom of the unit to see if I can see any part of the heat exchanger. Thanks for the help. I will let y'all know how it goes.
  18. #18
    Got it. I stood up on my chair and it finally sunk in what he was saying.
    Thanks.
  19. #19
    NE wisconsin
    I was standing on my toilet when I finally got it.
  20. #20
    Oct 2011
    Chicagoland Area
    Quote Originally Posted by philjafo View Post
    Seat up or down?
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
