+ Reply to Thread
Results 1 to 17 of 17
Thread: 4 way reversing valve question
    Feb 2011
    Atlanta, Georgia
    I was just reading in my school book that when installing a 4 way valve it should not be subject to excessive heat.
    I was presented a question stating when brazing a 4 way reversing valve heat absorbing paste should be placed around the body of the valve to minimize the chance of internal damage to the valve.
    Book doesnt clearly indicate if this is a fact or bull poo. A little help would be great.
    houston, texas
    A lot of guys use the paste, never have myself. They make a fork shaped tool for the torch that will allow you to heat all three pipes at one time to minimize the heating time needed to remove the valve.
    You can also use tubing cutters to remove the old one and then just fit the new valve in place. If you unsweat the valve be ready for an unpleasant experience with the phosgene gas you'll encounter.
    I'm not tolerating Political Correctness anymore, from now on it's tell it like it is.
    Veto Pro Pak - The best tool bag you'll ever own
    Feb 2011
    Atlanta, Georgia
    I am guessing according to your statement that this can be a true statement. If the valve is heated with no protection there is a chance that the internal components can be damaged.
    Jul 2001
    Southern NJ
    You should do something to protect the valve:
    Use the paste you're talking about
    wrap the valve with a rag
    use a lot of heat so you can braze really fast.
    Any of the above works, a combination of 2 is even better.
    Ryan
    Maintenance Guy
    naysayer, skeptic, conspiracy theorist
    Nov 2010
    Nebrasky
    alot of guys will use 45% rod instead of 15 so they don't need as much heat, it's more expensive though.
    Dec 2010
    Palm Beach,Fl.
    There are teflon seals and seats inside that can be damaged if they get too hot.
    I usually unsweat the discharge line and cut the other 3 at the easiest spot where I can add couplings and remove the whole assembly and mark the positions of the pipes before unsweating them from the valve itself. If i cant get a tubing cutter in there I have no problem taking them off with a sawzall, cut flush with the joints and use reducer couplings to go into the new valve.
    Sweat the stubs into the new valve one at a time with a wet rag to keep it cool and then reconnect the piping with couplings.
    Mar 2011
    Manchester NH
    Quote Originally Posted by SoFlaDave View Post
    SoFladave your not worried about any metal shavings getting inside the lines by using a sawzall. Just wondering??
    Winter Haven, FL
    A while back a member posted pictures of how to change the valve using stubs and such. I think he submerged the valve in water (I know it doesn't sound logical) and brazed his stubs on. He might of used wet rags. Might be worth running a search.
    Grottoes VA
    Quote Originally Posted by HVAC-matt View Post
    The discharge line is on the bottom, unsweat that and cap the line going to the compressor. Cut the other three, the shavings will fall into the valve your taking out, its already bad whats it gonna hurt.
    Mar 2011
    Manchester NH
    Quote Originally Posted by karsthuntr View Post
    Ok I was just wondering bc in school they had told us never to use a sawzall or hack saw. Makes sense thanks.
    Apr 2005
    where the beer flows like wine
    Quote Originally Posted by Texas-Tech View Post
    I thought we were beyond that point!!brazing/un-brazing etc does not generates any phosgene gas, another old wives tale.
    Dec 2010
    Palm Beach,Fl.
    Whatever the compound thats produced when refrigerant passes through a flame actually is, its extremely unpleasant at best.
    Dec 2010
    Palm Beach,Fl.
    Basically, if it can be done with tubing cutters, by all means thats the best way. Sometimes you gotta do what you gotta do though.
  14. #14
    If you're changing out the valve I would sawzall the top 3 lines at the bad reversing valve body so that you have the female side of the reversing valve connections still there then in unsweat the discharge. unsweat the top 3 female prices of copper left then clean up your ends. You should have some play in the discharge to start fitting the valve in now. It takes some work to fit the top 3 in but it can be done. Use thermopaste and a lot of heat and braze back together and instantly cool off with a wet rag. You should be good to go.
  15. #15
    Grottoes VA
    Quote Originally Posted by m8j4c View Post
    If you cut the top three without unbrazing the bottom one your shavings will fall into the comp. discharge line.
  16. #16
    Nov 2010
    Nebrasky
    I agree. plus it can already be a cluster in there, especially on WS HPs. I prefer to unsweat everything and have as few joints to braze as possible.
  17. #17
    Quote Originally Posted by hvacpope View Post
    he didn't imply phosgene gas was generated he stated encountered, you should have been in the cramped area i was in unsweating the 4 way valve i replace saturday, plenty of hacking and coughing going on
    any trapped gas is going to be unpleasant
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
