yeah
change out everything that says Lennox!!!
Sounds like a wiring issue. You say you've replaced different components, but are you sure you installed new components that are good??? I've seen plenty of motors bad outta the box. I've also seen plenty of defrost controls bad outta the box. Time to go back to sqare one.
Also, apply for pro. We can't really help you here in open forum. So thats all I will say.
