Go Back   HVAC-Talk: Heating, Air & Refrigeration Discussion > The ARPA Zone/General Discussion Forums > Residential HVAC
Residential HVAC Questions and discussions pertaining to HVAC for the home. No pricing, no DIY, please read Site Rules Register
Reply
Thread Tools Display Modes
  #1
Old 12-01-2009, 05:50 PM
letango letango is offline
Regular Member
I finally got a company to have an engineer look at my house in No. VA. He said a 3 ton A/C was all I needed, not 3.5, and certainly not 4 ton like one quote suggested. Here is what they are suggesting.
How does this system look?
Does it meet the Fed tax credit requirements?
Is there any Carrier rebate on any of this or has that program expired?
*3 ton high efficiency 17 SEER A/C model# 24ANA736A with r-410 puron
*matching 3 ton cooling col with r-410 model# C36A210C536
*100K BTU variable speed gas furnace Infinity series M# 58MVC100 (supposedly infinite gas control)
*Infinity thermostat
  #2
Old 12-01-2009, 06:46 PM
Wire-by-Colors Wire-by-Colors is offline
Regular Member
I am a commercial installer/ tech and I installed the Infinity system in my home this past summer. I elected to install the dual fuel option as that was what I previously had installed. The Carrier hybrid heat is amazing and I would recommend stepping up to the 58MVC furnace. I originally had a 100 MBU furnace that was 80% efficient. With the 58MVC, I have a 95% efficient unit that steps the output down based on demand; it is essentially a 3 stage furnace rather than a modulating furnace as advertised. The induce draft motor and blower motor are both ECM and therefore are the only part that modulates. Whisper quiet and my home's temperature and humidity have never been a steady as they have been this year. I even dumped the Honeywell Enviracom IAQ Zone system and installed the Carrier Infinity Zone system. The two stage heat pump was a tremendous performer this past summer and has thus far exceeded my expectations this fall. Not that I have an issue with Amana, but their design and construction seem substandard when compared with the Carrier product. Personally, I would not have entertained a Carrier product prior to this, but given the fact that 80% of the residential market is covered by some United Technologies brand equipment, the Infinity system was a perfect fit for what I wanted in my home.
By the way, the Carrier unit at 4 tons which is what I have is 7/8" vapor line and 3/8" liquid line. The 3 ton two stage is likely a 3/4" vapor line. I would recommend one last thing; have the existing line set flushed with a reputable product and not just Nitrogen. I like the R11 Flush that is available at the parts houses here in Atlanta... I am sure that its available in VA as well.
  #3
Old 12-01-2009, 08:50 PM
dash's Avatar
dash dash is offline
Location: Office and warehouse in both Crystal River & New Port Richey ,FL
AMEN!
__________________
Consumers with questions are welcome by many on this site,no DIY's see the "Rules"
If you don't feel welcome at first ,check back for more serious replies from Pro's that are more interested in assisting ,than attempting to be a comedian.
  #4
Old 12-02-2009, 12:51 AM
mwjhvac's Avatar
mwjhvac mwjhvac is offline
Smile
AGREE
  #5
Old 12-02-2009, 08:27 AM
Regular Member
Carrier quote fixes lineset issue
An engineer finally came out from my preferred choice company and said the house only needed a 3 ton system. My original long lineset problem is therefore solved since I don't need a larger tonnage A/C. That information also allowed for a 2 stage compressor rather than a single stage compressor. THis is the only contractor that tried to do any load calculations or send a specialist out to check on the needs of my house.
The downside is the price is now higher in the end because I believe the Carrier instant rebate program expired, right?
  #6
Old 12-02-2009, 08:58 AM
MoveOver MoveOver is offline
Regular Member
Rebate will be back this April. Also do you really need a 100K Furnace. Did they do a calc on the furnace too or just the AC. Small investment in the building envelope can reduce the size of the Furnace.
  #7
Old 12-02-2009, 09:54 AM
wahoo wahoo is offline
"Free" Rebate?
Many of the "lnstant" rebates are available from "participating dealers only". So you may actually get a lower price once "rebate" expires since many dealers must "hide" the price of their "participation" within their bid. Never such a thing as a "free" rebate. Participating dealers usually pay a portion of the rebate, and therefore must pass along their cost to the consumer (You).
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
» Sponsors
» Sponsors
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
HVAC-Talk is proudly provided by:
Contracting Business MagazineAd Management by RedTyger
© 2010 Penton Media, Inc.
