No. I just got on here because I've been gone for several hours. I'm not always on the computer, especially week days because I'm a substitute teacher.
Do you ever leave your computer? You respond faster than anyone I know.
I'm not sure that I understand your question. Every supply will need to have a damper IF you want to control the airflow for that supply run.
I do have a supply in my house that I let blow "wild". In other words, it is never restricted and that was designed that way on purpose.
Oh sorry. I kinda get it. So does that mean that if having the basement zoned off from the first floor system will only require very few dampers like for example 2 dampers (one for the basement, one for the first floor)? I don't know much about zoning. I'm still trying to learn about it and I'm still confused.
Okay, sorry, it seems elementary to me. Here is how it goes (generally), there are exceptions, of course:
If you had 12 existing (supply) registers on the first floor and installed 8 new (suppl)registers for the basement, then you are going to have a total of 20 dampers.
Now, once the dampers are in place, you may, depending on the layout of the home, have 4 zones without adding dampers. Understand better?
I need to read and then take my (beauty) nap. I'll respond to your posts a little later. Don't worry.
You are fun to "talk" to. I have always appreciated people that want to learn and are open to new ideas.
That's fine. Right now I don't have anything else to say, but that could change.
Not to intrude here, but have you considered how much air leakage you have at your rim joists? This is a major source of air leakage. That drop ceiling is not going to stop it either. The best first step regarding comfort & energy use in a home is to find out if your home has excessive air leakage and perhaps insulation issues, resolve those issues first, and then move on to equipment concerns.
tipsrfine thanks. I can see how that should be checked first. We have had our insulation inspected last summer.
Did you have your homes air leakage tested, with a blower door test?
Nope, but we do plan to have that done in the near future. I can definitely tell how important that is.
Here's a look of the first floor supply plenum: One of the 4 inch supplies on the right side of the plenum serve a half bathroom and the other 4 inch on the right side serves one of the vents in the kitchen. There are two trunks on the left side.
It was meant to be? That sounds more like it. In that case you would need a total of 23.
See, I can add as well. You would need additional supplies for the basement to make it work.
That would have been done before the basement finish. Zoning, originally, would have been less money than you spent on the system you have now without consuming the space it requires. Not to mention one less system to service.
Maybe GA needs a new HVAC shop?
Sweet Jesus! I thought you said the first floor system was nothing like the poor workmanship in the basement? I cannot tell the difference. Triple wow!
Lord help you! Is that how all the homes are in GA? Sorry, but I wouldn't take that on a bet......whatever that means. Sorry..........I feel for you folks.
Sometimes I can't tell what you mean about poor ductwork! Well our basement ceilings are lower than most homes around here, and It was harder to them to install the ductwork because of the low ceilings. The basement ceilings are 8 foot (except for the 3 rooms with drop ceilings which make those rooms 7 inch). The ductwork was never prime sealed on the first floor system when it was installed.
