Go Back   HVAC-Talk: Heating, Air & Refrigeration Discussion > The ARPA Zone/General Discussion Forums > Residential HVAC
Residential HVAC Questions and discussions pertaining to HVAC for the home. No pricing, no DIY, please read Site Rules Register
Reply
Thread Tools Display Modes
  #1
Old 10-08-2009, 03:22 PM
andythedrew andythedrew is offline
Regular Member
Quick Question
Is a 24x30 filter grill large enough for a 3.5 ton system?
  #2
Old 10-08-2009, 03:46 PM
jpb2's Avatar
jpb2 jpb2 is offline
Maybe...... Maybe not....... Details ?????
__________________
  #3
Old 10-08-2009, 04:10 PM
udarrell's Avatar
udarrell udarrell is offline
The more free-air Filter Area the Better
Quote:
Is a 24x30 filter grille large enough for a 3.5 ton system?
Yes & No...
RETURN AIR FILTER RACKS
A filter grille is not to exceed Manual D's 300-fpm maximum velocity.
Use the tonnage's CFM /divided by filter grille's free-air-area = FPM velocity.
You really can't have too much filter grille area; more is always better because they are always loading.
It all depends on the type of filter! Typical disposable 1-inch capacity return air filter is 2 cfm per square inch of gross filter area. Recommended actual filter velocity is 300-fpm or less, lower is better.
Filter Velocities higher than 500 fpm will decrease filter performance. Increase flow resistance, and possibly blow off collections of debris. Measure Velocity 1” from RA grille face.
Average Free Air area of most Return Air grilles about 75%.
75% of 720-sq.ins., is 540-sq.ins. of free air area.
So, what is the filter's free-air-area?
The filter mfg'ers ought to be required to list the free-air-area of their filters, & then state on the packaging or on the filter, the limit of CFM to stay within 300-fpm velocity through a clean filter.
To achieve 300-fpm through a clean filter, you would need 700-sq.ins of free-air-area / 144 = 4.886111-sq.ft., | 3.5-Ton @1400-cfm / 4.86111= 288-fpm velocity through a clean filter. (Edited)
Then how much free-air-area does that filter design have?
It depends on the type of filter(s) used.
Most 3.5 to 5-Ton systems require two filter racks exterior of the airhandler to achieve a low enough air velocity through those filters. Most 4 & 5-Ton systems nearly always have too much air velocity through initial clean filters, let alone when they begin loading. - Darrell
__________________
udarrell
Last edited by udarrell; 10-08-2009 at 05:33 PM. Reason: 300-fpm or less... depends on the type of filter(s) used
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
» Sponsors
» Sponsors
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
HVAC-Talk is proudly provided by:
Contracting Business MagazineAd Management by RedTyger
© 2010 Penton Media, Inc.
