Go Back   HVAC-Talk: Heating, Air & Refrigeration Discussion > The ARPA Zone/General Discussion Forums > Fireplaces
Fireplaces Questions about fireplaces? This is the place.
Reply
Thread Tools Display Modes
  #1
Old 02-24-2008, 11:13 AM
flat river fire flat river fire is offline
Regular Member
Csst
How Prevalent is the use of CSST (corrugated stainless steel tubing) with the hearth industry in the rest of the country. Has anyone had any code, or inspection related issues with using this product.
  #2
Old 02-24-2008, 11:58 AM
wisc wisc is offline
We have used it on fireplaces and furnaces (Gastite brand) since 1993 with no problems. The manufactures have a detailed instruction guide with sizing charts.
Read the manual from cover to cover.
Some common errors I see:
1) grounding of the piping system incorrectly. Usually the ground wire is undersized, and/or in the incorrect location.
2) protection from nail penetration
3) not sleeving the CSST where it passes into the fireplace box
4) use of 'soap' as a leak detector. Chlorine, brass and stainless don't mix well.
5) using it in exterior applications without protection or stripping the casing back so the stainless is exposed
6) having it pass through the furnace cabinet to attach directly to the gas valve
7) using it as an appliance 'whip' behind a range or dryer
In a related subject - Maxitrol regulators using vent limiters need to be installed horizontally (with the vent up) so the vent limiter can work. I don't know how many I've seen installed vertically on the drop to the furnace or water heater.
  #3
Old 02-24-2008, 12:06 PM
Regular Member
Familiar story
I've used gastite brand for approx. 8 years and have recently switched to Trac-pipe. Depending upon the inspector, you may or may not be allowed to whip into a fireplace even if it is jacketed. Safe bet for me, just don't. I do love this stuff for retro installs though.
  #4
Old 02-24-2008, 08:51 PM
jtp10181 jtp10181 is offline
Regular Member
Quote:
Same here, we used Gastite but switched to TracPipe for a huge cost savings. Almost every plumber in the area uses it for everything. Most of the time a main trunk is run in with hard pipe and then CSST is branched off to each appliance. Except the furnace and water heater which are right under the trunk line are usually 1/2" hard pipe. We see primarily Wardflex (cheap IMO) and Gastite, and sometimes other unknown brands.
  #5
Old 02-25-2008, 08:39 PM
bonafide's Avatar
bonafide bonafide is offline
Quote:
Plus trac pipe has higher EHD, at least thats the way it used to be over gastite. been using trac pipe for years, I still like to break out the old power threader on those show case your talent jobs
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
» Sponsors
» Sponsors
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
HVAC-Talk is proudly provided by:
Contracting Business MagazineAd Management by RedTyger
© 2010 Penton Media, Inc.
