Results 14 to 17 of 17
    Aug 2011
    Lewes, DE
    comfortnet stat doesnt control humidification, only dehumidification in ac mode by not jumping into high stage cool. It is a neat controller and i used to use them all the time....that is until they stopped giving them away for free!
    Jan 2006
    Quote Originally Posted by Gross View Post
    OK, so the way it's hooked up right now seems to be correct in that it is using the Control 60 humidistat that came with the AprilAire 600 humidifier. As I mentioned before, the humidifier turns on only when there is a call for heat. It will not work in fan only mode. The tech couldn't figure out how to wire it up like that. I'm not sure that's even possible.
    Aug 2011
    Lewes, DE
    Quote Originally Posted by nicksan View Post
    It's possible but a bypass humidifier won't work too Well w/o the heat from the furnace operation so I'd say your installation is correct
    Jan 2006
    OK, thanks for confirming!
