    Mar 2006
    Post
    I have forced air 84000btu oil furnace and aircondition installed. Due to problem with furnace would like to replace oil furnace with High Eff Gas furnace.
    Do I need to replace the Air conditioner coil as well ? or I can keep it.
    Washington
    You can keep it as long as it will match your new furnace size-wise. That being said, make sure during replacement they perform a load calc. It my expose the cooling part to being improperly sized.
    Jan 2006
    any qualified hvac contractor will normally evaluate your air conditioning system before installing a new furnace.changing the evaporator coil along with a new high efficiency condenser will save you money in the long run.have a load calculation done to ensure the proper sizing of your equipment.
