Page 1 of 5 12345 LastLast
Results 1 to 13 of 62
    New Jersey
    I haTE lennox!!!!!!
    Anytime I ever touched one of these (LENNOX) THINGS..
    I always need to get to suttin...even JUST TO CHECK A SMALL THING....but to do it.. I HAVE TO REMOVE almost AN ENTIRE SYSTEM.
    WHY?? is my first question ??? ////lol
    2nd and main one is this......
    Lennox unit
    Model # 6CSO6 - 036 - 90 - 3P
    Serial LOOKED like LG600C 06284 not sure on these digits though
    Anyway..I need a direct spark igniter....THATS ALL for this. When I call anywhere from Grainger to Johnstone supply...I get the same answer of..............
    "We have to contact lennox on the specs for that., we'll get back to you within 48 hrs."
    48?????
    “If I have seen further than others, it is by standing upon the shoulders of giants.” ~ Sir Isaac Newton
    I'm learning all the time, the tombstone will be my diploma!!!
    Did you ever stop to think, and forget to start again?
    Mar 2010
    Houston
    Serviceability of units in the field seems not to be on the radar of many manufacturers. I bet this would change if some of the design engineers had to spend a season servicing installed units for a season.
    SE Michigan
    It will probably be a whole new ignition kit and wiring harness too...with instructions that cover 10 different models and 10 different new diagrams you stick on the door.
    “Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery.”
    Mar 2011
    far southwest chicago suburbs
    Not a fan of lennox or carrier furnaces when it comes to service. It is freaking pain just to clean the dang flame sensor on a lennox...
    Oct 2011
    Arkansas
    Quote Originally Posted by Tommy1010 View Post
    Lennox unit
    "We have to contact lennox on the specs for that., we'll get back to you within 48 hrs."48?????
    I order Lennox parts online and usually have them in 48hrs.
    Ontario Canada
    At-a-boy Davie........
    Never give up; Never surrender!
    Lennox would not like/help you anyway because you could not get the correct model number.
    You could tell the owner you cannot fix the Lennox.
    carthage ms
    part number for the ingnition module is 49w66, the ignitor electrode itself is a 80k09, this parts fit the gcs16-036-90-3p machine with a serial date code in 03 that was the best i could come up with given the above numbers, the parts are also available in all of the parts centers in the southeast (thats all i get to see ) and in the north american parts center in marshalltown iowa, hope this helps you
    Gary
    The 2008 NATE TOP TECH!!!!!
    Jun 2007
    Round Rock
    It seems Lennox is a PITA to deal with. I've had problems getting parts in a timely manner several times. More than with anybody else. I had a lady request a Lennox the other day. We put one in about 8 years ago and she has had no problems out of it. Her 2nd floor Lennox is 25 years old with no problems until the other day when the gas valve died. She opted for a new system for that one rather than fix the old thing.
    I like DIY'ers. They pay better to fix.
    May 2009
    Lennox equipment is OK, but getting parts is a PITA unless you are a dealer. Product support is pathetic.
    New Jersey
    Quote Originally Posted by just_opinion View Post
    ha?
    Southeastern Pa
    Tommy, are you looking for the "blue box" that the high tension lead is fed from?
    It should have the number of seconds of prepurge and the number of retries printed on it.
    UTI now makes them.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Dec 2011
    somewhere between here and there
    Quote Originally Posted by rusty1217 View Post
    carriers 80% line is the easyest thing to work on,the highs are not so bad...way better than rheem
    Please, Please Please......keep the Factory Smoke in the Wires!!!!!
    Is it Rum'Oclock yet???
