    Mar 2006
    I appreciate advise on Infinity 80 size, whether to use 58CVA070-12 or 58CVA-090-16 on 1900 sq ft, 1st floor.
    1st floor split to be replaced is:
    - gas furn. 58PAV070-12, out_cap= 53K; in_BTU= 66K.
    - 2.5T A/C (builder grade: 38CK030).
    ---------Low Out Cap/In BTU-----Hi OutCap/In
    070------35K/43.5K (80.45%)----54K/66K (81.8%)
    090------47K/58K (81%)---------71K/88K (80.7%)
    Will set TSAT at 78 in summers; 68 in winters. We'll use Infinity control.
    090 has better SEER/EER/HSPF and less annual expense in ARI directory for the coil and Carrier Performace 2.5T heat pump.
    Note: I backed off 2-Infinity HP because not in till May, price, oversize concerns, and other. Hybrid split replacemt got pushed out till next wk.
    Thanks, AAR
    [Edited by aar on 03-17-2006 at 12:36 AM]
    SW FL
    Note: I backed off 2-Infinity HP because not in till May, price, oversize concerns, and other. Hybrid split replacement got pushed out till next wk.
    What is the age of current system?
    What is the objective of the replacements ?
    1. More comfort
    2. < Operating cost
    3. Pay-back
    Designer Dan
    Mar 2006
    12 yrs old. The fan in furnace broke but I think its not just the fan but more to it. I was told at this is age things turn downhill; fix, then something else emerges or breaks.
    THroughout the 12 yr old neighborhood, we are noticing same: HVAC replacements, regardless of HVAC brand.
    The carrier & power company spring rebates are influencing an iota.
    --AAR
    Mar 2006
    My apologies: 11 years old.
    And yes, upon deciding to go replacement route, then all three in your list are objectives.
    Re: comfort, we've been OK with 2.5T in 1st level for 11 yrs. If I bump up to 3Ton, it would be in 2nd level's system after I replacng the 1st level's split.
    re: op cost, yes, I would want to minimize but there are tradeoffs.
    re: recover cost, I assume you mean home value. The main thing towards that I see is R-410 . There is no realistic hope on recovering part of cost (like remodelling a kitchen or bath) but pls elaborate on whatever I'm missing.
    Thanks,AAR
