Results 1 to 13 of 17
01-04-2012, 08:24 AM #1
- Jan 2012
- 10
Loud continous hammering noise from Trane heat pump
Hello, This is my first post of this forum and I hope someone can help me out.
My trane heat pump (around 10 years old) works fine in cooling mode and seams to heat ok in heating mode, but whenever the temperature outside gets downs probably lower than 40 or so there is a loud continuous hammering noise coming from the outside unit and I am afraid something is being damaged......it is doing it this morning...outside temp is around 35 and it is non stop whenever the outside part is running......any suggestions? Its been doing this for a quite a while....
01-04-2012, 08:36 AM #2
Is it a hammering noise or more like a tapping noise after it shuts down?
01-04-2012, 08:40 AM #3
- Jan 2012
- 10
Thanks for your reply....it is a loud non stop hammering while the unit is running....the noise stops immediately upon shutdown.....and it isnt a tapping...it sounds like it is self destructing......I am sure the neighbors hate it at nite when they are trying to sleep so we usually just shut it off and put more covers on the bed....
01-04-2012, 08:52 AM #4
Is this dual fuel or electric backup? How long has it been doing this? If it is dual fuel and is what I think it is it will quit in a month when the unit stops running and the contactor needs replaced.
01-04-2012, 09:05 AM #5
- Jan 2012
- 10
By dual fuel do you mean gas....then no...only electric backup.........
01-04-2012, 09:25 AM #6
Professional Member*
- May 2011
- Ripley, WV
- 818
Can you post a video so we can hear the hammering sound? I have 2 ideas and I'm sure there are others with more but if we see/hear it might help.
01-04-2012, 09:27 AM #7
- Aug 2007
- Northern VA 38 degrees N by 76 degrees W
- 3,251
also post model #
01-04-2012, 09:55 AM #8
- Jan 2012
- 10
I will try to get video....I turned it off earlier cuz I was afraid it was going to blow....turned it back on now....( a little warmer outside) and it is running normally.....I will also get the model number if I can find it....
thanks for all the input...
01-04-2012, 10:07 AM #9
- Jan 2012
- 10
Got a video in .mov file format....what is best way to link to a reply....
01-04-2012, 10:21 AM #10
- Jan 2012
- 10
Ok...here is a link to the video at photobucket...warning...turn down your speakers......this is really the way it sounds.....
http://s727.photobucket.com/albums/ww279/DaveT053/AC/
01-04-2012, 10:41 AM #11
- Aug 2007
- 3,251
Definitely the compressor,I would turn it off till they get there
01-04-2012, 11:22 AM #12
- Jan 2012
- 10
Is there a reason that it only does this in heat mode ????
01-04-2012, 11:32 AM #13
Just cant stop a trane.
"If anybody can draw on the power, where do we put the meter?" - JP Morgan before pulling Tesla funding
