    Mar 2006
    I have a Trane heat pump and XT500C thermostat. Currently, the heat and cool temperature set points can not be any closer than 4 deg. Is there a way to change this to 2 deg? I live in Florida and in sping and fall (and winter) it is cool in the morning requiring heat and then warms up enough by afternoon requiring cool. With the 4 deg temp setting we are always having to tweak the temp. Thanks.
    Jun 2001
    Louisville, KY
    3F is the closest it will go with a change to an option in the installer's menu.
    Do you still have the installation manual provided with the thermostat?
    Mar 2006
    I think I found a copy of the installation guide with the codes. I'll try it tonight. Thanks!
