Results 1 to 2 of 2
Thread: Trane VX90
    Mar 2006
    I'm experiencing a problem with my VX90 furnace. I'm receiving an "Inducer error" 3 flashes when the furnace is calling for more heat and the first stage has run for it's timed 10 min. It should switch to its second stage and the blower should ramp up but doesn't. Any ideas as to what my problem may be?
    Sorry folks if this is a repeat not sure if i posted properly last time
    Flue or drain issue or on some of the older XV90s with board on the inducer, just a bug they had. A dealer will need to check flue draft with a manometer or magnahelic.
