Results 1 to 8 of 8
Thread: hissing sound
    What does a hissing sound indicate at the metering device of a residential air conditioning system?
    Feb 2005
    Alabama
    I could give you some ideas, but they would be wrong according to RoboTeq.
    "If you can't fix it, don't break it."
    freon passing thru the piston. The hissing may continue for a few seconds after the unit turns off while the pressures equilize.
    Jan 2006
    Dayton, Ohio [USA]
    ditto, the sound could last for several minutes and is no reason to be alarmed
    Mar 2006
    canada
    means its working
    Jul 2001
    what if you aren't using freon? Would R-22 make a hissing sound? What about R410A. Is the hissing unique to freon?
    Jul 2005
    Orange County, NY
    No, the hissing sound is created by a drop in pressure. Same as if you where to kink a garden hose.
    Core
    Dec 2001
    No problem usually if you have a piston, but could be low charge in a TXV system.
