Page 3 of 3 FirstFirst 123
Results 27 to 39 of 39
  1. #27
    Jul 2005
    TRANE AND RHEEM R BETTER BRANDS--BUT THE INSTALL IS EQALLY AS IMPORTANT
  2. #28
    Apr 2006
    So Product has nothing to do with it?
    Yes, yes, I get it. Installer is the key.
    But isn't it possible to find installers who can do a great job with all of the brands you are looking at?
    Are you guys saying that if I find one or more installers that I trust to do a great job, that product still doesn't matter at that point?
    At some point, with installers being equally trustworthy across their product lines, product has to play a part in performance, right?
    At that point, low-end, middle-end and high-end makes a difference, right?
    Give Bob and your industry a little credit that he can find more than one capable installer and at that point, it is relevant for him to know which quality of product to go with.
  3. #29
    Jun 2001
    DFW
    product has something to do with it
    Each brand has such a wide variety of products, that brand name is not sufficient information to determine the quality of the product.
  4. #30
    SW FL
    Re: Why can't you answer the question
    Originally posted by bobbart
    Why can't you answer the question???
    "what is the best and middle end system" ..that's all. I am not asking about installers, I'm asking about brand names >>>>>(Amana, Rheem, Trane or York)
    BARD is the best for your mobile home!
    Designer Dan
  5. #31
    Can a middle aged fat woman get in on this? Take it from me and I own 23 units now, take a guess on which brands and I can just about say yes to all them. I CANT tell much difference in any brand, its all about the installer. The unit that is serviced by the most knowledgable, detail orientated HVAC guy seems to work the best, the ones serviced by the ones that have half brain seem to break down more often.
    IM CONVINCED brand really makes no difference.
  6. #32
    Mar 2001
    Ok I will answer you....LENNOX it is far better than any other brand!! Is that what you wanted? I have a Lennox system in my home and am pleased with it....but reading what I just typed I want to hit the clear field button because I don't buy that statement. There is NO BEST BRAND of equipment. A VERY good answer was just posted by CURIOUS GIRL.
  7. #33
    There are a few circumstances where brand really does matter.
    In my own case, I need a 2-ton air handler that cannot be wider than about 18". The only choice among major brands appears to be Carrier/Bryant, which makes a unit 17 5/8" wide.
    One problem with this guy's question is he did not specify what matters to him. So it's like asking "What's the best vehicle?", it's impossible to answer. But if you know you care most about safety, or fuel economy, in a certain size class, then certainly some brands do better than others. The OP says he just wants an average product. So yeah, he should rely on the best-recommended contractor in town to do a decent installation of whatever mid-line system that contractor prefers. Better yet, find a contractor who can draw out what's really important to the customer and is flexible enough to use the brand that best meets those needs.
  8. #34
    SW FL
    Re: You Are WelcoME.
    Ok...Thanks for you input,
    Bobbart
    If you buy anything but a TRANE
    you won't be on the tracks.
    Designer Dan
  9. #35
    SW FL
    Call Discount Eddie's on 5th & Main
    I now have the REAL Answer to the
    REAL SIMPLE Question ! !!
    The brand new one you can drive away
    without
    paying a penny.
    Designer Dan
  10. #36
    Trane has a 2 ton air handler that is 18" wide.
    2TGB3F25A1000A
  11. #37
    Ruud/Rheem make a skinny cabinet in 2 ton too... all the 2 ton A/Hs go up to at least 15 seer (without breaking out a product catalog) above that id have to look it up
  12. #38
    oops forgot to add,
    all 17" or under
  13. #39
    Thanks, kmills.
    I had not even looked at Ruud/Rheem.
    With the current Carrier/Bryant high-end supply problems,
    you may have opened up some possibilities for me.
    But I do want variable speed in the air handler,
    so until I find the product data, I don't know if the Trane and Ruud options still apply.
