Results 14 to 26 of 39
    Jul 2002
    Zelienople, Pa
    Re: Why can't you answer the question
    Originally posted by bobbart
    Why can't you answer the question???
    "what is the best and middle end system" ..that's all. I am not asking about installers, I'm asking about brand names >>>>>(Amana, Rheem, Trane or York)
    Use the brand that the installing company is most comfortable with...
    All of those brands are equal in my opinion...
    Jan 2002
    East Grand Forks, MN
    Just answer the question!!!
    Which one? Which brand do you want? Tell us which brand you want, then we'll give you the middle end system.
    Don't confuse us. It's a simple question, which one?
    Mar 2006
    I really think you guys don't know your profession
    I really think you guys don't know your profession, CAN'T ANWSER A SIMPLE QUESTION
    Mar 2006
    ok ..what about Trane?
    ok ..what about Trane? I'm having a sale person come this Friday from Trane.
    Bobbart
    midwest
    If you buy the best Trane system and its installed poorly the cheapest York system will out perform and out last it if installed correctly. You can substitute any brand name you want in the above and it will still apply. GET IT?
    Jacksonville, FL.
    Well, DUH!!
    Bobbart
    The Trane guy'll say Trane's the best, the York guy'll say York's the best, & so on & so forth.
    Bobbart, I would listen to what each salesperson says, see which one adequately addresses your concerns & needs, & see if any of them do a load calc. The one sales dude that answers all your questions AND does a load calc is most likely the guy to go with regardless of what brand he sales, since brand is irrelevant anyway.
    WHY?
    Mar 2006
    OK Thanks
    Ok...Thanks for you input,
    Bobbart
    Apr 2003
    Look bob, your question has an open end of answers.
    The equipment matters very little. As any and all equipment DEPENDS on a qualified installer to properly size, install and set up the equipment to operate with-in the manufactures specifications.
    So in the end, the equipment is only as good as the installer. So, get the best installer you can find and go with the equipment he recommends.
    Mar 2006
    Thanks Jultzya
    Thanks Jultzya..will do
    Bobbart
    Tyler, TX
    RSES Certificate Member Specialist
    Southwest Regional Association of RSES Secretary, 2017
    Nov 2000
    Eastern PA
    Now listen up Bob! There are no hidden agendas here, just factual help. You have been told that a Good man is what is needed to install whatever brand of equipment that is installed.
    As long as a Good man is used, you will be happy
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
    Senior Tech Guest
    Yah...and don't get rheemed.....or let anyone be ruud to you, and I would personally make sure it's a trane...d individual that does the job!
    Nov 2000
    Eastern PA
    So senior; you wanna play rough, eh?
    Make sure A man, a Good man does the job!
