Results 1 to 8 of 8
    Dec 2011
    Asheville, N.C.
    Compressor SR Problem.
    Working on Haier Wine cooler. Start relay bad. compressor-115, 165w, 2fla. OEM relay no longer available. Uses quarter sized metal disk thermistor in plastic case. Q: How to size start relay or thermistor to compressor?
    Dec 2011
    Michigan
    Who makes the compressor? Call distributor with MN they should be able to hook you up
    At least get the horse power a 3 n 1 will get it going
    Dec 2011
    Asheville, N.C.
    It's a LG. Called their tech and never heard back from them.
    Dec 2011
    Michigan
    Can you search by mn and track down horse power maybe btus from the internet?
    What is the model of the compressor?
    Dec 2011
    Asheville, N.C.
    Comp. is LG Mod.#NSA36LACG. Thanks. I'll check some more.
    Dec 2011
    Michigan
    Not having much luck on the horse power what is the size of the box, and application? (High temp)
    Sounds pretty small try a 1/5hp 3n1
    Jul 2000
    Guayaquil, EC
    I did a little Googling and found that LG NSA36LACG compressor has a capacity of 330 BTUH at -10 Deg F with R134A and it takes a P6R8MC start relay which is available here (with a substituted relay):
    http://www.searspartsdirect.com/part...FUmR7QodDFlgmQ
    I'm sure it's available from other sources...you just have to take the time to look for them.
    The compressor specs are here:
    Attachment 233921
    Dec 2011
    Asheville, N.C.
    Thanks for every bodys help. That should get this thing to cooling his wine!
