Results 27 to 39 of 40
Thread: Sluggish reversing valve
01-07-2012, 04:32 PM #27
01-07-2012, 04:37 PM #28
lions lair,
This is your first warning. Additional infractions may result in loss of posting privileges.
01-07-2012, 04:40 PM #29
- Dec 2011
- 18
The tech I am using is a certified Goodman dealer/installer and one of the bigest in the area. Also is the owners son of the company. Now during start up after the replacing of the service valve, unit in "cooling mode" little to no movement could be seen on the guages. Then the cycle of time begins and the pressure will rise but this is hit or miss.
01-07-2012, 04:46 PM #30
If the gauges aren't moving in cooling, NOW we're cookin...
There are only a couple things that I can think of that would cause this condition.
A GOOD tech shouldn't have a lot of trouble narrowing it down.
They've put 2 RVs in. What criteria did they use for condemning the RV?
How many more RVs are you willing to have them replace before they do some old fashioned service work and find the real problem?
01-07-2012, 04:50 PM #31
Lions lair,
It won't let you edit because I deleted your post.
See the rules for posting in the AOP Forums.
01-07-2012, 04:52 PM #32
- Dec 2011
- 18
jp,
I don't know, the tech was watching his guages but did show me that while in cooling mode, there was no pressure difference from the suction side to the liquid side. Turn the unit off, pressure stayed the same. Showing compressor was not moving refrigerant. Sometimes if enough time went by, the unit would just start doing what it is suppose to do, other times it doesn't.
01-07-2012, 05:00 PM #33
- Dec 2011
- 18
After the replacement of rv the first time, the unit worked for about a week, by hitting the rv valve would sometimes cause the thing to work again. May have been just a fluck that made it worked. When the second rv was placed in, system was flushed, thinking that a previous compressor problem may have left jumk in there. When that 2nd valve did not work from the get go u[pon startup but later did work for a bit off and on, now the compressor and outside THX valve is being looked at.
01-07-2012, 05:11 PM #34
- Dec 2011
- 18
Aw, I see what you are saying, I may not have been clear enough, we where in cooling for the pressure checks and even then there was hardly any pressure difference.
Just thinking about what I just said, if the inside THX was stuck open would this not allow enough restriction to see a pressure change? Just asking.Last edited by starwatcher; 01-07-2012 at 05:18 PM. Reason: did some thinking
01-07-2012, 05:57 PM #35
I don't think a TXV could cause that.
01-07-2012, 05:59 PM #36
Starwatcher,
"percussive" diagnostics are not professional techniques.
There is a way to diagnose an rv.
Beating on it is not it.
01-07-2012, 06:20 PM #37
01-07-2012, 06:22 PM #38
- Dec 2011
- 18
LOL, yes I know but the tech was not the one beating on it, I was between service calls just to get it to work. Besides I am a Boilermaker ( power generating) by trade, if something dosen't work we get a beater, if that don't work we get a bigger beater.
Joking aside, I know about things like checking the temp difference on the sides of the rv tubes and the magnets to check for movement of the valve. From what I have heard, there needs to be 50 psi to operate the RV and we are not seeing the pressure anywhere when it is in it's bad mood. Let me say thanks guys for your time and incite. This not being my area of expertise, I am learning more then a home owner or I care to know. At this stage of life I just want the thing to work and I am trusting those that work in the industry to do just that.
I've had problems from amost day one with quality control of Goodman products. I for one will never buy nor recommend them to anyone because of my tinted opinion. I may have gotten a lemon out of 1000's but it my lemon.
01-16-2012, 05:51 PM #39
- Dec 2011
- 18
Hi guys, just to keep you guys up on what is going on. Replaced the compressor and every thing works great. So a Copeland compressor can fail intermitant as I stated in a previous message. For whatever the reason there was not enough pressure build up forcing the scroll down to pressure the system up. There is an internal pressure check in there that must have went bad. Don't have time to go into it now will be back later to give more info.
