Results 14 to 26 of 40
    Dec 2011
    Here is a link to the video that explains it better then I could.
    http://www.youtube.com/watch?v=hapg3...feature=fvwrel
    Nov 2001
    east kansas
    I think Carrier used a simular compressor in their 5 ton HPs.
    And I thought, but might be wrong, that Goodman used some in their larger HPs. I can't find any supporting information on the Goodman. I did see some stuff on the Carrier Gemini (?).
    Here is a link.
    http://www.emersonclimate.com/en-US/...rotection.aspx
    Look for a lable on the compressor.
    Beware of advice given by some guy on the Internet.
    Quote Originally Posted by starwatcher
    The pressure is being taken at the shrader valves using the service ports.
    Hmmm.
    Methinks I've discovered something...
    Dec 2011
    Quote Originally Posted by Milk man View Post
    Here is a link.
    Milk man
    Sounds like a posibility but this happens in no logical order. The thing could be off for days and demand be in this no pressure mode, then is a short sometimes long time it run great. The compressor is down in the unit so right now looking for the label is a no go but I did have the old compressor sitting in the garage. Label on it was ZPS51K4E-PFV-230-ZSM
    Hmmm.
    LOL... I'd be concerned if they weren't the same pressures in heat mode.
    Dec 2011
    Hmmm.
    I am all Ears!!!!
    When you said "service ports" do you mean the external ports on the unit?
    If so, then they should be within a few PSI of one another during heating operation.
    Maybe a wee bit higher on the larger line.
    Dec 2011
    Service ports are outside the unit at the service valves.
    You don't check operation in heat mode at both of the service valves. Neither of them are the suction/vapor port.
    Quote Originally Posted by starwatcher View Post
    starwatcher.
    You need a contractor or a tech who is well versed in Heat Pump service.
    From the sounds of things, the techs you have are not.
    I'm no heat pump guru, but I figured this out pretty quickly.
    Try our contractor locator map.
    Dec 2011
    Leaving pressure gauges out of the picture, the unit in heating mode does not make the suction line hot! Sound of the compressor is harsh, sometimes it will stay that way for 5, 10, 15 mins before compressor smooth out to quite normal sound, suction line is now hot. the same process can be seen in cooling mode or defrost, if the compressor goes into the "quite" stage the deforst will produce steam, if it stays in the noisy mode no steam and no defrost.
    I will stand by my last post.
    The tech needs to sit there until the unit does it, then take the time to determine WHY it is happening.
    Sadly, I cannot do so from where I am sitting.
