Results 1 to 13 of 24
    Dec 2011
    Water Chiller Book
    Hello.
    I need a book that explains chillers. Does anyone know of any?
    arlington,va,usa
    I have never seen one book on "everything about chillers".
    So to start off --> How deep you want to go?
    All of the air-conditioning & refrigeration apprentice books have a very light weight chapter (which will get you started):
    "Refrigeration and Air Conditioning Technology" by Whitman, Johnson, Tomczyk.
    "Modern Refrigeration and Air Conditioning" by Althouse, Turnquist, Bracciano
    "Principles of Refrigeration" by Dossat has a good chapter on the refrigeration cycle. Which I think is useful.
    All of the manufacturers (YORK, Trane, Carrier) have Operations, Installation, and Overhaul Handbooks. They sometimes come with the equipment. The local tech rep has them. These are very nice.
    YORK and Carrier have courses on Operations and Overhauling. Entech (Garland, Texas) also has overhaul courses.
    Centrifugal Compressors are basically big industrial fans. Do a web search for Trane's "Air Conditoning Fans, Air Conditioning Clinic". Or Trane's "Fans and their Application in Air Conditioning. Applications Engineering Seminar". They talk about Fan Laws, and Surging.
    Techno design nerds use books like "Centrifugal Compressor Design and Performance" by David Japikse. And "Compressor Surge and Stall" by Ron Pampreen. These are for men who design compressors and turbochargers for a living.
    Hudson Technology www.hudsontech.com and redicontrols.com talk about removing excess oil from refrigerant.
    Machine Design information (gears, labyrinth seals, mechanical seals, o-rings, ball bearings, sleeve bearings, thrust bearings)--> you can start with college books for mechanical engineering. Beyond that you have to go to John Crane for mechanical seals, Parker for O-Ring Design Handbook (on the net), and others.
    he needs a book on 'residential chillers'.
    are you looking for:
    fundamentals
    application
    or
    design
    an internet search engine would yield you some prospects
    Dec 2011
    Quote Originally Posted by dandyme View Post
    fundamentals
    application
    or
    design
    Especially design.
    Dec 2011
    think of it as a big water cooler.
    It would be a small book
    i think that book on mcquays site is ideal if its application, refrigeration , then probably those old carrier trane hardbacks stan
    Keep it simple to keep it cool!
    Somewhere in the world.
    If you have lots of time to read this one is pretty extensive.
    Attached Files Attached Files
    A mind is like a parachute. It doesn't work if it is not open.
    The best part of going to work is coming back home at the end of the day.
    Hard work spotlights the character of people: some turn up their sleeves, some turn up their noses, and some don't turn up at all.
    Dec 2011
    Thank you for the PDF.
    and when you finish with that one, here
    i honestly thought i had every single hvac book and pdf!
    that is a good one!
    thanx
    Quote Originally Posted by york56 View Post
    Dec 2010
    Central US
    And another.
  14. Likes Bklyntek liked this post
