Results 1 to 12 of 12
    Apr 2005
    where the beer flows like wine
    Manitowoc ice error codes
    could anyone post the meaning of the flash codes. thanks!!!
    Jul 2000
    Treasure Coast/Florida
    They had four safety limits starting with the B-Series machines. The last two were eliminated when the Q-Series came out (or was it the J?).
    Apr 2005
    Ice, what was the meaning of the four? b series.
    Jul 2000
    Quote Originally Posted by hvacpope View Post
    That was the high discharge temperature safety limit. It might have been intended as a loss of charge safety, but I don't recall now exactly.
    BTW...I've never seen a machine with a safety limit #4, and rarely one with a #3. I think that's why they dropped them.
    Apr 2005
    Ice, thanks!!
    what was #3?
    Toronto
    3 was low discharge temp. You can put in a 50K resistor and forget about the thermistor altogether. This is as per factory.
    Jul 2000
    Quote Originally Posted by DoctorIce View Post
    Yes...that resistor will stop either a #3 or a #4. I had forgotten about that one.
    Dec 2011
    Michigan
    #1 60 min freeze 6 consecutive cycles
    #2 Max Harvest 3.5 mins 500 cycles (this was like 3 cycles on older models) 7 min on quad evaps
    #3 Water system this is only on new S models
    #3 was low discharge on some older models
    Sorry didn't see the attachment earlier
    WI
    here is a zinger to throw you off...a SL3 on a quadziller water cooled is a Low Pressure fault.
    Dec 2011
    Michigan
    Quote Originally Posted by jonbailey19808 View Post
    I did know that but I have yet to see a quadzilla I've seen lots 1800lb Scotsmans but mostly work on IB's on dispensers
    Apr 2005
    Quote Originally Posted by btack View Post
    that makes two of us
    Thank you guys!!!!
    WI
    Yeah there is not too many Quadzillas out there, espically water cooled, mainly huge places like Casinos that have them hooked to the cooling tower. Some big restaurants have the CVD version of the Quadzilla now.
