    Jan 2006
    Two years ago I replaced a 25 year old Williamson Tempmatic Low Boy - the one with tke round heat exchanger - with a Williamson Centenial LowBoy - with the square heat exchanger and two inspection ports on the front. The old one worked fine but was probably nearing the end of its lifecycle so time for a new one. Basically no soot in the new heat exchanger ( stock Carlin EZ Pro .75 gph) but it's difficult to get around the back of the heatexchanger with a brush.The older one was easy to clean with brush with a rounded handle. I clean the HX twice a season and have the furnace tuned/setup profesionally every two years (use about 300 gal oil/year). Any tricks or special tools to get around the back side of that square conner. Thanks as usual for any tips. I enjoy reading the posts. Mark S
    Apr 2004
    Maryland
    i have a small diameter hose i use for my soot vac, i can usually get around the backs of heat exchangers or at least close enough to get the soot sucked out.
    frank
    Properly setup, the Carlin Elite leaves nothing behind for vacuuming. At 300 gallons a year consumption, a heat exchanger cleanout is valid maybe every 5 yrs....really. Burner maintenance should be every other year too.
    Jan 2006
    Casturbo, thanks for your reply. You're right in that the Carlin leaves nothing behind. And I guess I'm lucky because my oil company suggests all the low end stuff I can do myself - oil filter, air filter, HX cleaning with a furnace brush, ect. I see you are right up the road from me. I'm in Madison. JJ Sullivan is the oil company. One of their techs set up a WM WTGO that I installed for my mom. He had a real passion for tunning it. A digital meter with a printout. Thanks again.
