Results 1 to 13 of 16
    Dec 2011
    Confused Carrier 23XL2110
    Slide vane replacement tools, parts list for slide vane rebuilds, help?
    East of big city prices.
    Per Graham try the search feature at the top of the screen.
    Oct 2011
    La.
    The tool kit costs almost 15K for screw compressor. If you do not plan on opening a compressor rebuild shop, I would suggest getting getting a rebuilt one from Carriers rebuild shop in Houston. It even comes with a warranty.
    Apr 2010
    KY,OH,IN
    Slide valve?
    May 2003
    yep---there be a slide valve for controlling load--about 5" in diameter and one inch thick and has an oring that seals it--the problem we had was it hunting and surging---all due to that oring leaking
    Rather be golfing!
    Feb 2012
    Sounds like the problem similar to Dunham-Bush screw chillers.
    May 2003
    I think I still have the tear down manual on that machine
    Rather be golfing!
    Feb 2012
    Quote Originally Posted by rimide View Post
    To which chiller, the Carrier or the D-B?
    May 2003
    carrier 23xl
    Rather be golfing!
    Feb 2012
    tools
    The only tools you need to do the slide valve is a special socet. Witch one depends on the compresser manufacturer. howden or ingersal rand. They are the only tools you need to buy from carrier i have the part # if you want them both are 1200.00 from carrier. If doing an overhaul do not buy there tool kit we had/made all the tools for 500.00. sorry about spelling
    Feb 2012
    Ingersoll vs. Howden:
    The last digit of the model number on the compressor nameplate (located on the side of the rotor housing) A “G” in the last digit of the compressor model number identifies an Ingersoll-Rand compressor and an “H” will signify a Howden compressor
    Jan 2012
    Chicago
    hey rimide would you have the tear down manual and or a parts list that you could email?i have the start up, operation, maintenance manuals but not the others
    Not in Iran
    Welcome new guest.,
    Don't forget the e mail in ur profile
    no signature blast'em man blast'em
    !!!KILL THE TERRORIST!!!
