Results 1 to 4 of 4
    Mar 2006
    Jersey Shore
    I have installed Peerless 90% boilers model PI-140 all with different vent pipe lengths. Pressure switches are getting stuck in closed position causing system to lock out we have replaced switches and adjusted as per factory recommendations. Has anyone had this similar problem? Any recommendations on repairing or causes?
    South Amboy, NJ
    yeah ive had to replace a few....couldnt figure out what the problem was though
    Apr 2005
    Howell, NJ
    try checking the board...it may be faulty....no need to adjust when pressure switch is stuck closed
    DuGotz
    Mar 2006
    you have to make sure that when it is in a lock out the inducer moter is not still running. if it is board might be bad.
