Results 1 to 9 of 9
Thread: Capacitors
    Dec 2011
    Capacitors
    How does one tell the difference in a run capacitor and a start capacitor by their appearance?
    Mount Airy, MD
    This is the tech to tech chat section.
    In "Any" open section it is against the rules to give out DIY advise.
    With that said, carry on....
    Jan 2011
    Dec 2010
    Palm Beach,Fl.
    Generally speaking start caps are usually black plastic and run caps are metal or gray plastic. The only way to know for sure is by looking at the capacitors value and knowing where it belongs in the circuit
    Quote Originally Posted by k-fridge View Post
    The laws of physics know no brand names.
    Sep 2009
    Stumptown,USA
    If you click on packard E training all your questions will be answered.
    Challenge yourself, take the CM test --- Certificate Member since 2004 ---Join RSES ---the HVAC/R training authority ---www.rses.org
    May 2010
    Oxford, UK
    They are in different bins in the truck
    Also if you fit a start cap where a run cap should go, they explode, often quite spectacularly.
    Aug 2011
    Goose Creek ,SC
    Quote Originally Posted by monkeyspanners View Post
    very informative . Its been slow these past couple of weeks ,might give that a try
    Gas and go does not apply to refrigeration
    leland nc
    sounds like fun especially when i have a pain in the ass costumer
    May 2010
    Oxford, UK
    Quote Originally Posted by tinknocker service tech View Post
    Yeah! learnt this after working on unit customer had tried to fix themselves, ran it up to see what it was doing (they reported it tripping overloads), thing ran ok then sounded like it was siezing up as the comp laboured and cap over heated, then all this smoke came out the electrics box, found a tiny start cap where two run caps should have been.
    Customer claimed no one had worked on it since last time we were there
