Results 1 to 7 of 7
    Jun 2009
    Albuquerque NM
    Indoor coil condensate produced during heat pump defrost?
    Is any condensate produced by the indoor coil during a heat pump defrost cycle? A friend told me it could happen, but it seems like the time would be too short to produce much of anything.
    Apr 2011
    SE Washington
    highly unlikely that could happen, the defrost cycle is typically time limited, and when its cold, the relative humidity is usually low, at least not enough to condense that fast
    Massachusetts
    After switching to AC mode during defrost, by the time the indoor coil got cold enough to begin condensing, the defrost cycle would, in all probability, be terminated and the unit shifted back to heating mode.
    Jun 2009
    Albuquerque NM
    Quote Originally Posted by skippedover View Post
    And, in the case of an upflow dual fuel system like mine it seems like even if the coil got a little wet, the heat from the furnace would evaporate any moisture off the coil right away.
    I guess it could be different in other configurations though.
    Heat pumps with a bypass humidifier could condensate a little.
    Jun 2009
    Albuquerque NM
    That's what I have, but it's dual-fuel in an upflow configuration. The bypass take-off is above the coil and the humidifier is on the return.
    I have the VisionPRO IAQ with DATS in the supply plenum, downstream from the coil. The system is set to humidify in "desert humidification" mode, so I believe the IAQ will shut off the humidifier if the supply air is too cold. But, the humdifier water panel is probably still wet for that amount of time.
    Indoor RH is only 30%, but if the humidifier is on I guess RH would be higher at the coil.
    Probably less then 30 seconds that the coil is cold enough to condensate moisture.
