Results 14 to 21 of 21
    Suppy NC
    may
    my supply guy told me it could control the blow now unless i was misinformed.
    i will look into this and will correct my comments it that is the case.
    either way a servie co should be able to match something up for humidy control with out over cooling the house
    Suppy NC
    pstu seems i misinformed you about the vision pro sorry
    may is correct
    i got one out of my truck i picked up today as stock and it does not control the blower. it will bring the ac on to three degrees below set point in an atemp to lower the humidity
    there are no ds terminal on the stat for the v drive blower control
    i should have looked at the stat instead of going by the counter guys word
    i will have fun with the counter guy tomorro
    4H: Hot, Humid Houston H.O.
    No foul, and thanks
    Thanks Mayguy and Tinknocker, for bringing out the corrected story so quickly. So I had only about one hour of thinking that I *must* get that VisionPro. Maybe I still will but with less over-the-top enthusiasm.
    Would it make sense then, to put a humidistat *and* a VisionPro together in the system? If it is a 2-stage AC, with perhaps a relay so that the humidistat sends its signal only in low-stage cooling? That would seem to dedicate high stage cooling more for sensible, and let latent do whatever it will. Eventually I am tempted to do just that.
    In the end, I still am admiring of the Honeywell VisionPro styling. I admire most of its functions, but if some other brand has an equivalent or better design, I would consider it too.
    Best wishes -- Pstu
    Rochester, MN
    hehe, Keep us posted!
    Unless he just got something in, and prove both of us wrong!
    Suppy NC
    pstu
    i will be glad to check with my trane supplier tomorro and see if there is a stat to do both. i know lennox has one but it has been awhile since i used trane
    Suppy NC
    pstu
    since you have a trane system call a trane dealor
    there are several options you can be given from them
    Thanks TinKnocker, I will ask him. This is something I have wanted for over a year, I am sure to say yes to something they offer!
    Best wishes -- Pstu
    If not VisionPro, then maybe Totaline 1400?
    It seems to me the Totaline top-of-the-line touch screen thermostat can work with a VS blower to adjust CFM in response to humidity:
    http://www.totaltouch.info/compare_products.html
    http://www.totaltouch.info/products.html
    There are a couple features which "wow" me that the Honeywell does not have. No doubt there is something inferior about the Totaline, but my hot button is mainly on VS fan control. I just wonder if any of the pros see anything with this stat that is a big negative. I'm nearly ready to write a check on this project.
    Best wishes -- Pstu
Plumbing Talks | Contractor Magazine
Forums | Electrical Construction & Maintenance (EC&M) Magazine
Comfortech365 Virtual Event
