Results 1 to 8 of 8
    Dec 2011
    Confused York Modulating Furnace vs Amana Modulating Furnace
    Which is better a York Modulating furnace or the Ammana Modulating Furnace. I was told that the York furnace is really modulating because of all the modulating stages it has? Does the Ammana furnace have the same ammount of stages? The quote prices are about the same and warranty is close any suggestions would be appreciated?
    Jul 2001
    Central MN and the Twin Cities
    We have installed bolth Amana and York/ Luxaire products..... I would put the Amana in my house.
    Warning: Just because I am over the head injury doesn't mean I'm normal!
    The day I stop learning.... I'm dead!
    Saint Joseph, MI
    Last I checked, the York I believe drops to 35% capacity while the Amana/Goodman drops to only about 40%.
    But the Amana equipment should be just a little cheaper, so I'd ask some more question s about the installation. Someone is either making a little more profit or cutting out something.
    Did either company do a load calculation? Or are they both quoting a 60k BTU furnace (the smallest modulatin furnace you can get anyway). If larger, they need to back-up the sizing, even if the existing unit is the same size.
    May 2008
    Missouri
    Amana has the complete unit replacement if heat exchanger fails to original owner. Don't think York has that warranty. I'd also get the 10yr. labor warranty included in quote.
    clarkie
    This is the Ask Our Pro's forum. In order to post advice here, you must have verified qualifications and have been approved by the AOP Committee.
    Further infractions may result in loss of posting privileges.
    Aug 2011
    Ontario
    You never said where you are located. Why are you looking at modulating. ??
    There is no bad beer, some just taste better than others.
    Jul 2001
    I completey disagree with your opinion of Amana should be cheaper then York. Its a superior product with a better warranty. We get bolth from the same wholesaler. Our profit is higher on the Amana only becausewe have far less callbacks and warranty calls.
    Don't make this into a price thread, they end up getting closed.
