Results 1 to 13 of 31
    Dec 2011
    Kyle, TX
    Compressor Problems and Hard Start recommended fix
    My AC unit has gone out. The outside condenser unit is making a god awful sound. The capacitor has been changed since the video below but it is still making the sound and not blowing cold air into the house.
    Does this sound like a killed compressor from a prolonged system failure? I am trying to learn the industry terms and how an HVAC system runs. I have not run across any thing where the condenser is making this noise and don't think that a hard start kit will help it. Is this the sound of the compressor trying to compress liquid? Again I am trying to understand the mechanics of the compressor and not asking for DIY help just what could be wrong with it. I have come to terms that I need a new unit. I was just wondering if the advice on a Hard Start Kit installing from a tech is the way to go or should I just save that money and put it towards a new unit.
    Thanks,
    http://www.youtube.com/watch?v=AZbvG...Z9fk2N8EFVqltD
    AC Specs:
    Carrier Model: 38BRc036330 (R-22)
    Houston,Tx.
    Probably one of those Carrier Millenium Compressors, if it is, you have been on borrowed time for probably 5 years.
    Dec 2011
    Kyle, TX
    If it is should I bypass the Hard Start Kit appt. tomorrow and just pick out another AC condensing unit? And I think it is safe to assume that I should not replace what I have with the same thing?
    Houston,Tx.
    Quote Originally Posted by forJAT View Post
    Well some compressors are just loud, like Bristols, yours sounds loud/bad but camera audio sometimes don't do things justice. How old is this unit? and if you change out the condenser, unless you go with the new 410A refrigerant type condenser and new evaporator coil inside,you will only be able to buy a builders grade R-22 condenser.
    Houston,Tx.
    Also fyi, the start assist/hard start is not going to do anything for the run noise, it will still be noisy.
    Dec 2011
    Kyle, TX
    Serial Number is 1303E45028 So I believe that it was manufactured in 2003. We moved into the house July 2003.
    The correct model number is 38BRC036---331--- and this was/is a builders grade 3 ton unit (first owners of the house).
    The noise coming from the condenser unit it loud as in you can hear it 3 houses away and I can hear it running in the kitchen through the Master Bedroom and the Living area.
    Was told that it was a bad capacitor, per the test the fan portion of the capacitor was okay but the compressor part was dead. For more durability he replaced the 50/7.5 370 with a 50/7.5 440 capacitor it still made the noise and was told that it needed a hard start kit installed. I was also told that the loud noise was the compressor trying to kick on but not getting there. -- if allowed it will make the loud noise for 30 min so I don't think that it is it "trying" to kick on as I have read that there is a shut off on compressor so it does not burn up.
    The camera audio does not give it justice it is louder than what was recorded.
    Houston,Tx.
    .For more durability he replaced the 50/7.5 370 with a 50/7.5 440 capacitor it still made the noise and was told that it needed a hard start kit installed. I was also told that the loud noise was the compressor trying to kick on but not getting there..
    Well in my personal opinion, someone is yanking your chain! Ask him if he installs the start assist and it still makes noise, will you give me credit for the first cap "you probably did not need" towards a new unit. Did you see him verify the MFD " micro farad" rating on the capacitor he took out with a meter?
    Dec 2011
    Kyle, TX
    I did see it on his meter it came up with nothing on the meter (his meter was strictly a MFD reader). I assumed that since it was not within the +/- 10% acceptable range it did not register on his meter.
    I did a capacitance test of my own and got this:
    Fan: 7.34 uf (consistently)
    Herm:
    42.84 uf
    43.03 uf
    43.24 uf
    43.22 uf
    I could not get a duplicate reading on it.
    So you don't think that the loud noise is the compressor trying to turn over (turn on)?
    Houston,Tx.
    Unless someone is hearing something different from my 60 year old ears hear, that compressor in the video is running, compressor don't just sit and try and start for 30 minutes, unless you are trying to start them with an automotive type starter and it's out of gas.
    leland nc
    mr bill is right dont waist your money on a hard start wont help
    look into a new unit where your money is better spent
    Dec 2011
    Kyle, TX
    Also I am assuming that the problem lies in the condensing unit as the heater works.
    Could a bad capacitor kill a compressor? I have read that compressors do not die but are killed due to system failure or from being over charged.
    Houston,Tx.
    Could a bad capacitor kill a compressor?.
    Yes it can, if left running to long on a lower/higher MFD cap. out of factory specs for that compressor.
    Dec 2011
    Kyle, TX
    Okay from the limited information that I have given and been told I believe that it is safe to say that my AC does not work and that it is more than likely due to the compressor (due to the louder than normal noise that it is making when on) also because the refrigerant lines are not cold indicates a bad compressor or no charge at all in the system as in a leak.
    Can I get by with buying the compressor noted below and then having a tech install it. I really can not afford to pay $Xk - $Xk to have a new AC unit installed. Or do I need to have the entire condensing unit replaced?
