    gas pressure adjustments
    While it glosses over the test procedure, it never says how to make adjustments to these valves. I will, therefore, assume no pressure adjustments are available and if not to specification, replace the valve.
    http://www.hearthstonestoves.com/ass...8531Manual.pdf
    http://www.hearthstonestoves.com/ass...8761Manual.pdf
    Aug 2011
    Ontario
    You are correct. If inlet pressure is right than outlet should be factory set. You can adjust max min on control knob, but nor really legal.
    There is no bad beer, some just taste better than others.
    this can be moved to Pro section if there is a way to do adjustments, I posted here for the proper section heading.
    My recommendations were to replace the valve due to many issues, but the major was the installation without a second stage regulator(propane).
